Sponsored by: Real Truck
help
Old May 2, 2015 | 08:17 AM
vinomakers's Avatar
vinomakers
help
hey guys ,
i have 08 f350 diesel super duty , as i was cleaning the truck i noticed the auto started hanging down from under the dash, so as i went to put it back under the dash it sparked and the truck shut off , i have checked all fuses under the hood an also pass side kick.
so two question
where are the inline fuses and what do they look like .
also i have no power to the key,
Old May 2, 2015 | 09:34 AM
clem1226's Avatar
clem1226
Is this a factory of aftermarket remote start?
Do you have the normal lights on the dash when you turn the key to run? Check engine, oil light etc?
Old May 2, 2015 | 10:32 AM
vinomakers's Avatar
vinomakers
no dash lights at all it is a after market Auto starter
Old May 2, 2015 | 11:51 PM
bayou barataria's Avatar
bayou barataria
May have blown the module if no fuses are blown, but probably a fuse some where you don't see. Get a bright flashlight and trace the wires to the module. Could also just be a loose connection, some times the alarm shops put those squeeze wire connectors that come loose when moved. Check all of your stock fuses as well.
Old May 3, 2015 | 06:24 AM
vinomakers's Avatar
vinomakers
Thanks guys it ended being a bad fuse ..they all tested good ,but after each use out if visually inspecting them we found the bad one..
kscards
Jul 11, 2015 09:02 PM
beanhead6D5
Jul 5, 2013 06:55 PM
Pwnm30rdi3
15
Feb 23, 2011 07:59 AM
dunbar15
Jun 2, 2010 08:31 AM
BigJ5656
Nov 30, 2009 12:34 AM
