steering column questions
Old May 1, 2015 | 03:44 PM
spikinfool05's Avatar
spikinfool05
hello im working on a 1986 f-150. 2wd auto. the tilt mechanizem went to crap. i found a parts column will the guts out of a 85 column work in my 86? also does anyone have a exploded view of the columns parts and how they go in? thank you have a great day.
Old May 1, 2015 | 05:39 PM
InfantryCPT's Avatar
InfantryCPT
Steering_Column
not sure this will help, but ctubutis should chime in shortly he was a great help on a column question I had
Old May 2, 2015 | 08:44 AM
ctubutis's Avatar
ctubutis
The guts from the 85 will work in the 86 but I strongly suggest you replace the entire thing as an assembly; steering columns are intricate assemblies with some tiny parts that all need to go together exactly correctly for it to work right.
In general, working on steering columns sucks....
Below is an exploded view from the parts catalog as well as the entire section from the shop manual (choose what pertains to you):
Old May 2, 2015 | 08:45 AM
ctubutis's Avatar
ctubutis
Old May 2, 2015 | 09:03 AM
InfantryCPT
wow and he came bearing gifts! Outstanding
Old May 3, 2015 | 02:21 PM
spikinfool05
ya holy cow. ya i already made the choice of taking it apart. i dont know why but i did its all back togther now. only thing that doesnt work is the tilt itself. thanks for all the help.
Old May 3, 2015 | 05:04 PM
xlhr8r's Avatar
xlhr8r
silly ?
Make sure you pull the tilt lever, not push...if you put it all together, it should work. Are you sure you did it right? Good luck.
Old May 4, 2015 | 10:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Below is an exploded view from the parts catalog:
Look at 3B661 in this parts catalog pic (it's a curved piece in the upper center of the pic). This is the tilt wheel locking lever, has serrations on it that wear down.
When this occurs, the tilt wheel will not lock in place, will just "flop around."
E2TZ-3B661-A (replaced D0AZ-3B661-A) .. Tilt Wheel Locking Lever / Obsolete
Applications: 1978/91 F100/350, Bronco & Econoline / 1970/80 FoMoCo Passenger Cars / 1981/90 FoMoCo Passenger Cars with the tilt wheel operated by the T/S handle.
No Ford dealer or obsolete parts vendor has any. AFAIK, it's not repro'd.
Old Dec 31, 2015 | 01:29 PM
billybl's Avatar
billybl
2nd Gear
Thumbs up Thank you ctubutis
I joined today, so that I could give a huge thanks to ctubutis for posting the scans of the steering columns.
ctubutis, You sir, are awesome!
That twice that you have saved my.. rear,, Thank you! - Thank you!
Have a wonderful New year everyone!
384
Old Dec 31, 2015 | 01:31 PM
ctubutis's Avatar
ctubutis
Thanks!
dthut
16
Apr 25, 2022 08:15 PM
Sunline Fan
Ford Truck Parts for Sale
373
Jan 29, 2015 09:40 AM
andym
General Automotive Discussion
Feb 4, 2012 04:31 PM
Marz-68
16
Dec 17, 2008 09:44 AM
