Emissions on my 84
Old Jul 27, 2003 | 05:10 PM
Stingray42's Avatar
Stingray42
Emissions on my 84
What emissions equipment is required on my 84 ford f150? right now there is a muffler and not much pipe.
Do I need cats, o2 sensors, etc?
Thanks
Andrew
Old Jul 27, 2003 | 05:17 PM
c_rossman's Avatar
c_rossman
Emissions on my 84
It depends if you need to get checked by a sniffer every year for registration. If not I wouldnt worry about emissions.
Old Jul 27, 2003 | 05:23 PM
Stingray42's Avatar
Stingray42
Emissions on my 84
I have to sniff test it when I register it, (20 years and older are exempt) so next year it doesnt matter. I hope that there was no cat originally, and that she will pass!
Old Jul 27, 2003 | 05:35 PM
fordnut71's Avatar
fordnut71
Emissions on my 84
ok what motor u got in there a 300 6 up to 86 dont have a converter on there if u got a v 8 u going to need 1 for sure if u not sure look on the rad support for what is required for emmissions it will say if a conveter is going to be required an all the related componteds.
Old Jul 27, 2003 | 08:04 PM
Stingray42's Avatar
Stingray42
Emissions on my 84
I have a 351W, the rad sticker doesnt tell me a whole lot, I dont see much of anything for cats. I was hoping that someone could point me to a source on here or tell me what is needed. BTW, I am in canada
Old Jul 27, 2003 | 08:19 PM
fordnut71's Avatar
fordnut71
Emissions on my 84
ok you going to have to have cats on there to pass for sure if u cant read the tag go to the scrap yards an get the info from it . after market cats installed are around $100
Old Jul 28, 2003 | 10:55 AM
gavin's Avatar
gavin
Emissions on my 84
My 1980 F250 w/ 351w was catalyzed. The trigger is GVW. <8000lbs was catalyzed, >8000 was not catalyzed. If you have any doubts, just call your DEQ, and they can tell you.
Old Jul 28, 2003 | 08:00 PM
NorthernFord's Avatar
NorthernFord
Emissions on my 84
The Sticker would say non catalyst equiped, my truck is also an 84 with a 302 and I have this sticker, but bear in mind that the sticker could have fallen off over the years, get the dealer to run your vin, or if they can't, I know that the MTO(ontario) can tell you.
Old Jul 28, 2003 | 10:49 PM
Stingray42's Avatar
Stingray42
Emissions on my 84
Hey, I checked today, and it says noncatalyst, so no cats, right?
WOOOHOOO!!!!
Will it still pass the sniffer one more year if it is a smooth runner???
Thanks
Old Jul 29, 2003 | 07:05 AM
82F100SWB's Avatar
82F100SWB
Emissions on my 84
I think it should pass if it runs good, but, I think it should be exempt due to the non-catalyst emissions system.
Just curious, but, does your instrument cluster say "unleaded fuel only" below the tach/filler panel where it would be, or on a sticker on the gas tank door or hinge?
I can't remember if my 84 had it on the cluster or not(it was a catalyst truck,) but, all of the earlier LD non catalyst trucks I have seen were equipped to run on leaded gas(I belive this was a Canadian market only option in the 80's), and the do no have the "unleaded fuel only" markings.
