My Ford won't start
Old Jul 16, 2003 | 01:11 PM
Lauralee's Avatar
Lauralee
My Ford won't start
My 85 Ford F150 was running fine, I parked it for about a week went to start it and nothing happened, it's not the battery. Does anyone know where the fuel switch is? I think this might be the problem but I don't know where it is.
Thanks,
Laura
Old Jul 16, 2003 | 01:16 PM
bigdmizer's Avatar
bigdmizer
My Ford won't start
only three reasons why an engine doesn't start. Fuel, Fire, Air.
Old Jul 16, 2003 | 01:55 PM
Lauralee's Avatar
Lauralee
My Ford won't start
Thanks for the helpful info.
Old Jul 16, 2003 | 07:46 PM
TwoF150's Avatar
TwoF150
My Ford won't start
Lauralee,
I am sure we can get you started.
What do you mean nothing happened? Do the lights work? Does it turn over? Is it making a clicking sound?
Old Jul 17, 2003 | 07:21 AM
Lauralee's Avatar
Lauralee
My Ford won't start
When I spray eather it starts, it's an 85' F150.
Old Jul 17, 2003 | 07:37 AM
Big Orn's Avatar
Big Orn
My Ford won't start
Have you got a "see-thru" filter on it? Can you see that it is getting fuel? I used to take loose the gas line and see if it was getting fuel until one of my freinds almost got burned up doing that. Since then I just go to the parts store and get one on those large clear fuel filter and install it in-line. That way not only can you see if its getting fuel, but you can see about how much - if its sporadic or not. It sounds like your fuel pump may be bad.
Old Jul 17, 2003 | 08:01 AM
Lauralee's Avatar
Lauralee
My Ford won't start
Thank you for the suggestion, I'll do that and I'll let you know what happens.
Lauralee
Old Jul 17, 2003 | 09:02 AM
PA F150 4X4's Avatar
PA F150 4X4
My Ford won't start
When you get it to start with starting fluid does it continue to run or does it shut stop when the fluid runs out?
Old Jul 17, 2003 | 01:32 PM
shortblock2000's Avatar
shortblock2000
My Ford won't start
DOES IT RUN FINE AFTER YOU START IT UP WITH THE ETHER?????
Old Jul 23, 2003 | 07:48 AM
Lauralee's Avatar
Lauralee
My Ford won't start
No it doesn't stay running. I haven't had a chance to buy the plastic fuel filter yet, but I'm going to give that a try.
Lauralee
Old Jul 24, 2003 | 10:13 PM
steve83's Avatar
steve83
My Ford won't start
It's a fuel supply issue, then. What engine? Is it EFI? Are there any modifications to the fuel system, like an aftermarket fuel pump? You've got to GIVE info to get it.
Old Jul 29, 2003 | 07:36 AM
Lauralee's Avatar
Lauralee
My Ford won't start
Thanks for your suggestions, I appreciate it! It was the fuel pump, all is well now.
Lauralee
lauraj
Feb 14, 2011 02:34 PM
Nyborg
23
May 23, 2008 04:06 PM
Laura Smith
Bronco II
Oct 27, 2004 02:11 PM
Laura's Truck
34
Apr 19, 2004 07:08 PM
laura23
Feb 15, 2001 08:31 AM
