Suspension upgrades
My Excursion has 270k miles and only thing changed were the shocks and hubs. I'm looking to redo my suspension. I am looking at the F250 leaf springs for towing but everywhere I read it lifts the truck 2". Being a 4x4 its already higher than usual, my sister had an 02' 4x4 but mine is higher. I don't want it to lift up. Are there springs that hold the weight of the F250 springs but don't lift the truck or is there something I can install so the truck won't raise. Any suggestions on steering and thing for the front end?
You need to read more!
You have most likely seen info on modded B or c code rear spring swaps (along with front V or X codes) and those do raise the ride height up by about 2" due to the "mod" part.
Most folks (or at least many folks...) are not too thrilled with the front springs and suffer from some extent of bottoming out in the front. This leads them to swap in SuperDuty springs (V or X codes) that firm up and raise the front by 1.5" (V's on a PSD) to 2.9" (X's on a V-10). To get better performing rear spring to match they usually go with either the SD B or C codes. These springs if left un-modded will have a nearly even ride height as the stock EX rear springs. The mod is done to raise the rears up to match the new increased ride height of the new fronts springs. If you are perfectly happy with your fronts currently then a swap to un-modded rear SD B or C codes should increase the rear load handling abilities and leave your ride height nearly unchanged.
Much info on these spring swaps can be found at the top of this forum in the Tech Folders.
When you say higher than usual, what are you thinking is "usual?" To what are you comparing it to?
If you're comparing your '00 4x4 to her '02 4x4 and both rigs are Excursions, you should be almost exactly the same height. If both rigs are indeed Excursions, how much higher does your sit, exactly? Is her suspension stock? Is it in need of repair?
Please remember, when a person swaps in V codes, B codes, and the F250 tapered block (or modded B's if no block is swapped) all a person is doing is bringing the height of a 4x4 Excursion up to the same stock height of a 4x4 F250/350, nothing else. If Ford hadn't screwed the pooch and put different springs on the Ex, an OEM 4x4 Ex wouldn't sit lower than an OEM 4x4 F250/350, it would sit at the exact same height.
Stewart
