302/351w question
Old Apr 30, 2015 | 03:43 PM
Furr308's Avatar
Furr308
302/351w question
Ive always been told that the 302 and the 351w were practically the same motor. I know that there is alot of interchangeable parts. Also, I know that the block is different, and the stroke on the 351 is longer, and the crank is different, and the intake. But the bore is the same and the cam and pistons, and I believe the heads too? Im fairly new to the engine world, so for discussions sake, is that true about the 302 and 351 being practically the same?
Old Apr 30, 2015 | 05:19 PM
Conanski's Avatar
Conanski
No it's not true at least not in the same way that a 305/350 are the same, the 302 and 351 share very few parts besides cylinder heads, they can also use the same cams, timing covers and water pumps but that is about it, everything else is different.
Old Apr 30, 2015 | 09:29 PM
baddad457's Avatar
baddad457
Ditto, heads and the entire valvetrain are the same, everything else is different. Pistons are the same bore size, but the pin height is different as is the piston top. Throttle body is the same, distributor cap and rotor the same, distributor itself is different.
Old May 7, 2015 | 12:22 AM
Frdtrkrul's Avatar
Frdtrkrul
351W has a bit wider and its also a bit taller than the 302.
broncrunner
16
Mar 17, 2006 09:14 AM
herothc2003
Engine Swaps
Oct 25, 2004 05:07 PM
Sandman1991
May 15, 2004 10:51 PM
btnbronc
Feb 2, 2004 02:57 PM
DS02F250
21
Mar 12, 2003 09:19 PM
