I bought a 2008 Super duty, it came with one key and a key fob.
It has the key pad on the door. The only way I can get it unlocked is with the key. I found the factory 5 digit code on the back of the fuse panel. I replace the battery in the fob.
I tried the factory code, doesn't work. I tried the reset procedure from the owners manual, I got a click from the door but didn't unlock or get a horn chirp. I'm an hour away from a dealer, so any help would be appreciated. Maybe I should keep my 96 F-150.
