Sponsored by: Real Truck
Bad MPG
Old Apr 29, 2015 | 07:55 AM
Big Camo's Avatar
Big Camo
Bad MPG
I have a 2000 f350 with ,Air Raid intake, Banks exhaust with exhaust brake, GTP38r, Boost fooler, AIH Delete, 6.0 trans cooler, billet converter, shift kit, DP Tuner, FRX, HPX, Isspro ev2 gauges on 35's
For the last 5 months I have been using a <acronym title="Miles Per Gallon">mpg</acronym> app to keep track of my trucks mpg The best I can get is 11.7 highway 10.4 in town and 9.5 towing. These seem very low compared to most guys.
I baby this truck and always try to keep it under 2000 rpms, any ideas what could be causing such bad mpg ?
Old Apr 29, 2015 | 08:16 AM
Pocket's Avatar
Pocket
First thing to always do when a 7.3L loses fuel economy is to check for boost and exhaust leaks.
Old Apr 29, 2015 | 09:15 AM
SuperDutyScaler's Avatar
SuperDutyScaler
Also check the exhaust back pressure switch for being clogged and clear out the tube. If either is clogged it will drop mpg
iPhone from IB AutoGroup
Old Apr 29, 2015 | 09:36 AM
Big Camo's Avatar
Big Camo
I have a banks exhaust brake there instead of the ebv. will the ebv switch and tube even matter since i dont have the ebv ?
Old Apr 29, 2015 | 10:06 AM
speakerfritz's Avatar
speakerfritz
how many miles on the engine.
Old Apr 29, 2015 | 10:19 AM
Big Camo's Avatar
Big Camo
just a hair under 180,000
Old Apr 29, 2015 | 11:32 PM
lawdawg79's Avatar
lawdawg79
Dirty fuel filter can hurt mpg as well
Old Apr 30, 2015 | 08:36 AM
Lattitude Adjuster's Avatar
Lattitude Adjuster
Turn your tuner back a little and see what happens to your mileage.
When I bought my truck, the PO had the tuner set to "race truck".
I was getting 12 miles / gallon, sound familiar?
I turned the tune down to mid range and got all the sensors (including the exhaust back pressure switch) working.
I average about 21+ mpg on the interstate at the speed limit and 16-17 around town.
Most of the time for a tank of normal mixed city hiway driving the lie-O-meter is around 19.5
This is a 2002 CCLB 4X4, 7.3 with 250K on the clock
LA
Old Apr 30, 2015 | 12:08 PM
Fishin76's Avatar
Fishin76
Thats not where the sensor is though. The sensor is on the front of the engine, to the left (as you face the engine) of the HPOP reservoir. ( near the AC compressor pulley.) A 'sensor on a stick' is what it looks like. it is mounted on the end of a vertical tube.
Check this one. if it is unplugged, plug it in. Otherwise, Remove the sensor, clean it, take a piece of wire to the tube and make sure the tube is clear, (not plugged up).
Change the fuel Filter. and air filter.
Otherwise, if that doesn't help, My suggestion is take it for a good aggressive drive with a big dose of Diesel Clean (grey bottle) in the fuel tank. I think since you've been driving so nicely, the pistons and exhaust valves are collecting soot. (carbon). Run it really good, stretch it's legs, make it breath heavy.. Blow some of that old snot out of it.. get it up to temp for a good while.
Then when you notice a difference in performance, change the oil and filter.
Old Apr 30, 2015 | 12:51 PM
Pocket's Avatar
Pocket
The sensor will not have any effect on fuel economy, especially if the truck has ditched the EBPV for the aftermarket exhaust brake.
The primary function of that sensor is EBPV operation.
For any vehicle that is losing fuel economy with no MIL illuminated on the dash, maintenance items are the first to look at. I assumed the OP had already checked the normal stuff such as air filter, tire pressure, alignment, oil and filter, etc.
With the 7.3L in particular, if maintenance items check out fine, the most common suspect is a boost and/or exhaust leak. It's extremely common on these trucks, especially if there has been any modifications performed in the past.
A truck with an upgraded turbo...... I'd be looking at the up-pipes right behind the turbo first.
Old Apr 30, 2015 | 01:23 PM
Fishin76's Avatar
Fishin76
I dare you to unplug it and drive a tank out.. You don't get a code, or a warning light, but it does matter. It does effect MPG, and power. Backpressure affects injection timing, which effects power and MPG..
May not matter on your modified truck, but for a stock truck, it matters..
Old Apr 30, 2015 | 08:36 PM
Pocket's Avatar
Pocket
Been there done that, with many different tunes and also with stock calibrations. Tested it long before I swapped injectors. Tested with the stock EBPV pedestal unplugged, also tested with EBPV delete with stock pedestal, and with a fully deleted pedestal.
Tested with sensor unplugged. Tested with sensor plugged in but removed with a cap on the end of the sensor, and the tube plugged (ran that one for about 2 years actually).
All tests resulted in MPG change = zero
And please understand that timing does not look at backpressure. I know because I do my own tuning, so I can see what the calibrations are looking at.
Old May 1, 2015 | 06:07 AM
Bently_Coop's Avatar
Bently_Coop
Maybe time to check the brakes as well. Super Duty's are known for sticking calipers. In fact I am in the middle of sorting mine out. Started lubing everything up and found a frozen slide pin.
tuffnufly81
6.4L Power Stroke Diesel
Jan 13, 2013 02:25 PM
adam10
13
Jun 3, 2012 04:24 PM
A/Ox4
May 21, 2011 08:13 PM
deercreek1
Apr 23, 2008 10:04 PM
mud rat jr.
15
Dec 29, 2006 06:22 PM
