Just did this myself 2 weeks ago and used the 20mm freeze plug. It was a little large, but took a dremel to the outside of the plug and in the hole just a bit. After that it was a socket just smaller than the inside of the freeze plug and a hammer for persuasion. Destroyed the first one, but the second one caught and went straight in.
Good luck with this.
Vince
This is exactly what I did. Also heated the housing a little too
