spring flush and fill
Old Apr 27, 2015 | 10:42 PM
96_F250_Deezal's Avatar
96_F250_Deezal
Thumbs up spring flush and fill
I noticed several months ago the coolant temp gauge wasn't getting up to normal operating range, hooked up the scan tool and confirmed coolant temps were staying around 172* F.
popped the hood and found the coolant overflow tank was low, tried to remove the coolant cap and it just spun with a random clicking sound... never came off.
Decided it was time for a Mishimoto 200* thermostat, new coolant overflow tank and drain the Green Zerex low silicate coolant and refill with Cat EC-1.
I found a source for the Cat EC-1 coolant at MHC truck centers and it was less expensive, @ $12.60 a gallon, than I expected.
I got the new overflow tank installed, drained the coolant and pulled the thermostat to discover my truck has an aftermarket thermostat and housing installed and the Mishimoto thermostat doesn't fit in an aftermarket housing.
I ordered a motorcraft thermostat and housing from Rockauto and was able to install the Mishimoto thermostat in the motorcraft housing.
Old Apr 28, 2015 | 12:21 PM
Rusty Axlerod's Avatar
Rusty Axlerod
After your flush there will be a lot of water in the cooling system. It's hard to keep your 50/50 mix if it's 50/50 coming out of the jug. Concentrate coolant is better and CAT dealers aren't big on stocking it.
Old Apr 29, 2015 | 01:49 PM
Mishimoto's Avatar
Mishimoto
Former Vendor
Very nice, sounds like you are ready for hot-season. Thanks for picking up our thermostat. Let us know what you think after you put some mileage on the truck!
-John
Old Apr 29, 2015 | 07:50 PM
11jjonn's Avatar
11jjonn
Rusty is being too easy on you.
DO NOT USE 50/50 MIX.
INSTRUCTIONS ARE VERY SPECIFIC ABOUT USING CONCENTRATE.
After multiple fill/drain with distilled water, close all plugs/pet***** and pour in 3.5 gallons of Concentrated ELC-1.
Top off with distilled water. You now have a 50/50 mixture.
Old Apr 29, 2015 | 08:59 PM
96_F250_Deezal
calm down... it will be Okay.
Old Apr 30, 2015 | 07:39 AM
mohoneywell's Avatar
mohoneywell
the reason its only $12/ gal is because its half water already....
Old Apr 30, 2015 | 02:47 PM
Tampa250's Avatar
Tampa250
At least around here, NAPA carries the Zerex CAT-approved ELC in both full strength and 50/50 varieties. Interestingly enough, the price is about the same for either "flavor".
Old Apr 30, 2015 | 07:57 PM
Rusty Axlerod
I skipped my local CAT dealer the second time around. I had to order and wait for it the first time. The guy at the counter said " all we ever use is the premix" three times at least. Made me feel like a jerk for insisting on the concentrate. I found Shell Rotella at my local Tractor Supply. Silicate free, CAT EC-1 rated, concentrate for a decent price.
Old May 25, 2015 | 09:43 AM
96_F250_Deezal
coolant is flushed, new thermostat installed and truck is running well.
I am seeing 203*-207* coolant temps with my scan tool. I am guessing its still burping all the air out.
Hopefully the fuel mileage goes up.
DJayAce
2004 - 2008 F150
Nov 28, 2016 05:12 PM
JAMSRF250
Sep 18, 2013 11:04 PM
catman52987
Sep 19, 2011 08:07 PM
paulkcbulm
Aug 30, 2010 09:50 PM
jaberwocky
2004 - 2008 F150
23
Feb 20, 2009 01:26 PM
