A/C not working
Old May 17, 2015 | 02:58 PM
dondolittle2's Avatar
dondolittle2
A/C not working
Hello everyone I'm back, after searching all the post I can, I've still not found the answer I want or need. I have a 04 f250 6.0. Just replaced the a/c compressor A/C was working great until the clutch bearing decided to fail.
Replaced the compressor placed two cans 134A jumped the low pressure switch not working. To make sure the compressor is good I jumped a hot wire to compressor and it worked, the fuse is good I don't know where to go from here.. Can anyone Help Thanks
Old May 17, 2015 | 03:07 PM
dannyboy950's Avatar
dannyboy950
Remember the A/C clutch is on a seperate fuse. Did you pull down a vacum on it before adding the 2 cans? Did you jumper the low pressure switch? IIRC it takes 3 cans before the clutch will stay in on it's own and it will cycle properly.
Old May 17, 2015 | 03:11 PM
dondolittle2
Yes I forgot to mention I pulled a vacuum and I jumped the low pressure switch. Where is the clutch fuse my panel doesn't say.
Old May 17, 2015 | 03:33 PM
dondolittle2
I checked fuse F2.10 it is good HELP PLEASE
Old May 17, 2015 | 05:28 PM
dannyboy950
In the underhood box it is fuse17 10A on a 05.
Old May 18, 2015 | 04:32 AM
dondolittle2
Thank you I appreciate the much needed help
Old May 20, 2015 | 06:34 PM
dondolittle2
A/C working
A/C working now but the coolant fan isn't working with the A/C on. The fan works or seems to work but it should come on when I turn the A/C on. Is there a relay or switch that pulls the fan on?
Old May 20, 2015 | 06:45 PM
npccpartsman's Avatar
npccpartsman
The fan is PCM controlled and there is more than one parameter that's considered. Try turning the A/C on max cool and see if the fan operation becomes a bit more robust. As long as the truck isn't overheating it's fine.
Old May 20, 2015 | 07:00 PM
dondolittle2
IF THE FAN DOESN'T COME ON WHEN THE A/C IS TURNED ON THE HEAD PRESSURE ON THE AIR COMPRESSOR GOES WAY UP SO THE FAN HAS TO RUN TO BRING MORE AIR OVER THE CONDENSER.
Old May 25, 2015 | 06:26 AM
dondolittle2
A/C Not Working
Can't believe no one knows the answer to my question!!
Where is the fuse or relay for the coolant fan located? on an 04 F250 6.0
and the fuse box isn't under the hood it's under the steering column.
Old May 25, 2015 | 06:49 AM
dondolittle2
I have power on the two bottom wires on the plug at idle with or without the A/C turned on, no power on the other there, at any time. Anybody got any ideals?
Old May 25, 2015 | 06:52 AM
dondolittle2
I'm thinking the PCM or the fan may be bad. Power thru the PCM would be variable ( I think) So it would not be a bad relay. Am I right?
Old May 25, 2015 | 07:11 AM
dannyboy950
You have 2 fuse boxes on a 6.0. Yes the voltages to the cluch fan are PCM controled and variable because the fan is variable. It is not just on and off.
As previeously mentioned several sensors are involved with A/C and clutch fan operation.
Old May 25, 2015 | 08:45 AM
87crewdually's Avatar
87crewdually
The fans on these trucks don't come on fully like an electric fan on a car.
If you have high pressures spiking in the A/C system then you may have a clogged orifice. When I change out compressors the orifice tube and dryer get changed and the system is flushed.
Also check for a clogged condesor. Dirt and bugs will restrict air flow making it inefficient.
Old May 25, 2015 | 10:04 AM
dondolittle2
Not clogged orifice the fan isn't turning fast enough for the condenser to dissipate heat to keep head pressure down. Fan just isn't turning fast enough at idle
