Parts Help Please
Old Apr 27, 2015 | 09:52 PM
Chevmn56's Avatar
Chevmn56
Parts Help Please
Does any one out there know the part number and if there are any NOS/OEM available of the Clutch rod and two bushings.....this is the long rod that goes through the floor pan, it hooks to the clutch and brake assembly inside the cab and then attaches too the equalizer bar.
Thanks so much
1978 F250 4X4 400m manual
Old Apr 27, 2015 | 10:52 PM
privateer, eh's Avatar
privateer, eh
check 77&79f250's sticky on the top of the page, theres bound to be a parts diagram listing and showing everything
Old Apr 27, 2015 | 11:48 PM
burnthelight88's Avatar
burnthelight88
Does it have to be the stock numbers? Because I know Jeff's Bronco Graveyard has the parts you need, I just ordered one of the bushings the other day
Old Apr 28, 2015 | 01:19 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Chevmn56
Does any one out there know the part number and if there are any NOS/OEM available of the Clutch release rod and two bushings.
This is the long rod that goes through the floor pan, it hooks to the clutch and brake assembly inside the cab and then attaches to the equalizer bar.
1978 F250 4X4 400 manual
1978 F100/350 I-6 & V8's: TWO different clutch release rods, TWO different bushings, as it depends on what the serial number is.
Serial number is the last 6 digits of the VIN, post what it is...so I won't have to type 4 different part numbers.
btw: The LMC catalog info for these parts is WRONG! So don't buy the parts from them.
Old Apr 28, 2015 | 03:14 AM
Chevmn56's Avatar
Chevmn56
Hey number the serial number is BE1088
Old Apr 28, 2015 | 11:49 AM
NumberDummy
D8TZ-7521-B .. Clutch Release Rod / Obsolete
Applications: 1978 F100/350 & Bronco from serial number BA0,001 / 1979 F100/350 & Bronco.
USD INC. in Phoenix AZ has 1 = 602-253-7111.
BURNS FORD in Burns OR has 1 = 541-573-7278.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
RPN PARTS in Erie PA has 3 = 888-864-9305.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
VINTAGE PARTS INC. in Beaver Dam WI has 6 = 877-846-8243.
2) D8TZ-7526-B (replaced D8TZ-7526-A) .. Clutch Release Rod Nylon Bushing-7/16" I.D. / Obsolete
Same applications as above.
PARTS INTERNATIONAL in Farmers Branch TX has 8 = 888-727-0418.
RPN PARTS has 14.
BURNS FORD has 19.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 387 = 800-476-9653.
skidoorulz
Mar 22, 2015 12:26 PM
mosigndude
Jan 1, 2015 07:43 PM
68f250guy
Jan 22, 2012 01:19 PM
zx7rhitch
Oct 22, 2007 10:01 PM
geraldww
Nov 19, 2003 09:49 AM
