van turbo ww2
Old Apr 28, 2015 | 04:37 PM
SkySkiJason's Avatar
SkySkiJason
I had no problems even at 8k ft elevation...
Now, at 12k ft I needed to put the chip in 'stock' tune to keep it clean...
Too bad I can't change my tuning! Every time I go up there to hike and play it almost kills me... Walking and talking at the same time are not an option!
Old Apr 28, 2015 | 04:44 PM
SkySkiJason
Because we all like pictures... Stock on left, van turbo and outlet adapter on the right.
And FUBAR turbine wheel from the turbo that failed when I was on the road. (And I swapped out on the side of I-81...)
Old Apr 28, 2015 | 05:14 PM
white Buffalo's Avatar
white Buffalo
Originally Posted by jhl3
OK. Air density?
I live at 2600' and tow from sea level up to about 5500's with the majority at around 1800'. Which would be best for my application?
Or is it not that simple?
For me it's more about what the vehicle is used for mostly (towing, racing, street fun), your specific setup and driving habits(rpm range).
It's not one size fits all. I really enjoy towing with the Stage 1 sticks & Van turbo in our F-250 like SkySkiJason does. It has worked great for 8+ years...But I enjoy "street fun" driving more with the excursion with the quicker boost spool from the .91 AR housing on the S366.
Here is a great Explanation from Garrett I refer to a lot:
A/R (Area/Radius) describes a geometric characteristic of all compressor and turbine housings. Technically, it is defined as:
the inlet (or, for compressor housings, the discharge) cross-sectional area divided by the radius from the turbo centerline to the centroid of that area (see Figure 2.).
compressor housing showing A/R characteristic
Figure 2.
The A/R parameter has different effects on the compressor and turbine performance, as outlined below.
Compressor A/R - Compressor performance is comparatively insensitive to changes in A/R. Larger A/R housings are sometimes used to optimize performance of low boost applications, and smaller A/R are used for high boost applications. However, as this influence of A/R on compressor performance is minor, there are not A/R options available for compressor housings.
Turbine A/R - Turbine performance is greatly affected by changing the A/R of the housing, as it is used to adjust the flow capacity of the turbine. Using a smaller A/R will increase the exhaust gas velocity into the turbine wheel. This provides increased turbine power at lower engine speeds, resulting in a quicker boost rise. However, a small A/R also causes the flow to enter the wheel more tangentially, which reduces the ultimate flow capacity of the turbine wheel. This will tend to increase exhaust backpressure and hence reduce the engine's ability to "breathe" effectively at high RPM, adversely affecting peak engine power.
Conversely, using a larger A/R will lower exhaust gas velocity, and delay boost rise. The flow in a larger A/R housing enters the wheel in a more radial fashion, increasing the wheel's effective flow capacity, resulting in lower backpressure and better power at higher engine speeds.
When deciding between A/R options, be realistic with the intended vehicle use and use the A/R to bias the performance toward the desired powerband characteristic.
Here's a simplistic look at comparing turbine housing geometry with different applications. By comparing different turbine housing A/R, it is often possible to determine the intended use of the system.
Imagine two 3.5L engines both using GT30R turbochargers. The only difference between the two engines is a different turbine housing A/R; otherwise the two engines are identical:
1. Engine #1 has turbine housing with an A/R of 0.63
2. Engine #2 has a turbine housing with an A/R of 1.06.
What can we infer about the intended use and the turbocharger matching for each engine?
Engine#1: This engine is using a smaller A/R turbine housing (0.63) thus biased more towards low-end torque and optimal boost response. Many would describe this as being more "fun" to drive on the street, as normal daily driving habits tend to favor transient response. However, at higher engine speeds, this smaller A/R housing will result in high back pressure, which can result in a loss of top end power. This type of engine performance is desirable for street applications where the low speed boost response and transient conditions are more important than top end power.
Engine #2: This engine is using a larger A/R turbine housing (1.06) and is biased towards peak horsepower, while sacrificing transient response and torque at very low engine speeds. The larger A/R turbine housing will continue to minimize backpressure at high rpm, to the benefit of engine peak power. On the other hand, this will also raise the engine speed at which the turbo can provide boost, increasing time to boost. The performance of Engine #2 is more desirable for racing applications than Engine #1 since Engine #2 will be operating at high engine speeds most of the time.
Old Apr 28, 2015 | 05:23 PM
white Buffalo
Here is the link:
http://www.turbobygarrett.com/turbobygarrett/turbine_housing_AR_and_housing_sizing
Old Apr 28, 2015 | 05:45 PM
white Buffalo
For those interested:
There are 4 differences between the stock Super Duty turbo and the Van turbo.
The van turbo uses a larger 1.15 a/r exhaust housing and a truck uses a .84 a/r exhaust housing.
The van turbo's 1.15 housing is Non-wastegated and the truck's .84 is wastegated.
Because of the different housings the outlet flange that connects the turbo to the exhaust pipe is different. You can see this in The photo.
The Exhaust wheels are different as well. the wheels start the same but are trimmed differently.
A truck turbine wheel has a 76.20mm inducer and a 67.73mm exducer.
The van turbo turbine wheel has a 76.20mm inducer and a 69.84mm exducer. Slightly bigger on the smaller end of the wheel.
Both start with the same compressor wheel = 60mm inducer and an 80mm exducer.
Old Apr 28, 2015 | 06:37 PM
Dan V's Avatar
Dan V
So, I will assume that you guys recommend this over the 38r. If so, why, besides the bearing?
All in, all done. ..I would likely have went with the 38R, but I was already in deep with this.
Old Apr 28, 2015 | 09:23 PM
SkySkiJason
Yep, 160/0's and S366 is a sweeet towing combo and fun as hell even in my 6spd. I went from a 1.0 38r to the .91 S366.
Now, I tow a lot less and daily drive a souped up TDi wagon - so I'd really like hybrids and a bigger charger for the dually!!
Old Apr 29, 2015 | 10:32 PM
snakedoc's Avatar
snakedoc
So far dd is good towed 6000lbs did great before I would surge and have to back out of it now I can keep the foot in it and go depper gaining speed in the hills. I do fill it's upped the hp a little and the power on the pull is strong.
Old Apr 30, 2015 | 06:48 AM
white Buffalo
What was the difference in EGT's for you?
Old Apr 30, 2015 | 09:29 AM
SkySkiJason
Anxious to hear that too!
When I had BTS tunes in my Excursion, I had to really try hard to see 1200* - ever. Like 24k lbs GCVW and hammer down pulling Appalachian mountains in the '100hp' tune. That was with the stock turbo and full factory exhaust. It was even harder with van turbo and 4" exhaust.
Once upon a time I had different toons, and I could probably see 1200* between red lights and mountain towing was drive-by-pyro even with a 40hp 'high altitude' tow tune. I just had to run 'stock' above 5000ft...
Old Apr 30, 2015 | 02:05 PM
snakedoc's Avatar
snakedoc
There about 100 less top temp was 900 and I was deep in the pedal and steady speeding up.
Old Apr 30, 2015 | 03:07 PM
jhl3's Avatar
jhl3
Could you share the artist who was the creator of the "toons"? Does veggie seem to increase or decrease EGT's?
Old May 3, 2015 | 07:23 AM
  #28
SkySkiJason
That was with DP Tuner... (and before the loss of 2 engines )
Good timing is more important than feeling like the truck is faster. EGT's never being a problem was just one benefit of better tuning... I'm just gonna leave it at that.
I don't notice any changes running WVO except my exhaust smells like BBQ chicken (or funnel cakes or Thai food, etc.) I have well over 200k veggie smile-miles on my dually now and put 120k miles on my Excursion using the high-cholesterol fuel. And I recently got an '03 TDi Jetta Wagon that has been veggin' for about 175k miles!!
JayTheCPA
Mar 30, 2016 06:42 AM
comadvan
19
Jan 29, 2012 12:51 PM
john8403
Apr 11, 2011 09:32 AM
canister
13
Apr 25, 2010 01:18 AM
PSNut
Jan 26, 2006 08:43 PM
