1997 TEMP GUAGE PROBLEMS
Old Apr 27, 2015 | 08:54 AM
MR6X6's Avatar
MR6X6
MY 1997 F350 4X4 C&C ,7.3 TRUCK IS HAVING A PROBLEM WITH NOT REGISTERING THE TEMP GAUGE CORRECTLY. I PUT IN A NEW TEMP SENDING UNIT AND IT PEGGS THE DASH GAUGE OVER ALL THE WAY... SOMEONE MENTIONED THAT THERE IS AN ANOTHER SENDING UNIT TO CHANGE ALSO ?WHEN THE OLD GAUGE WAS IN IT ONLY READ PARTIALLY. ANY IDEAS OR HELP WOULD BE APPRECIATED..THANKS
Old Apr 27, 2015 | 09:52 AM
85F350IDI's Avatar
85F350IDI
Originally Posted by MR6X6
MY 1997 F350 4X4 C&C ,7.3 TRUCK IS HAVING A PROBLEM WITH NOT REGISTERING THE TEMP GAUGE CORRECTLY. I PUT IN A NEW TEMP SENDING UNIT AND IT PEGGS THE DASH GAUGE OVER ALL THE WAY... SOMEONE MENTIONED THAT THERE IS AN ANOTHER SENDING UNIT TO CHANGE ALSO ?ANY IDEAS OR HELP WOULD BE APPRECIATED..THANKS
Nice caps there, and if it's pegged I believe you should try checking the ground wire
Old Apr 27, 2015 | 09:57 AM
85F350IDI's Avatar
85F350IDI
I had asked about my temp gauge because mine doesn't move at all
Originally Posted by Fastback460
One way to figure out which isn't working is to unplug the wire from the top of the sender, and then ground it somewhere on the engine or firewall.
Then while you are doing that have someone inside the cab and watch the gauge. If the needle goes up when you ground it, then it's probably the sender, if it doesn't move then it could be the gauge.
Old Apr 27, 2015 | 11:09 AM
Fastback460's Avatar
Fastback460
I agree, the ground wire is the first place I would check.
Old Apr 27, 2015 | 12:43 PM
MR6X6's Avatar
MR6X6
THANKS GUYS
Old Apr 28, 2015 | 02:21 PM
MR6X6's Avatar
MR6X6
97 TEMP SENDING UNIT`
THANKS FOR THE INPUT GUYS. WAS WONDERING IF ANY OF YOU HAD A THOUGHT ON THE SECOND PART OF MY QUESTION ABOUT SOMEONE TELLING ME THERE IS ANOTHER TEMP UNIT THAT ALSO NEEDS CHANGING? IS THIS TRUE? IS THERE ANOTHER TEMP UNIT ALSO ON THE 7.3 ENGINE ?
Zack12
Apr 4, 2015 08:50 AM
1991ford_trucker
Oct 29, 2010 08:45 AM
Jason316
Mar 30, 2010 06:56 PM
bgcustoms
1983 - 2012 Ranger & B-Series
Jun 26, 2007 05:14 PM
nc150
Electrical Systems/Wiring
Nov 2, 2006 06:19 AM
