RiffRaff High Flow Fuel CVD Fitting Set
Old Apr 27, 2015 | 01:08 AM
OldBlackCat's Avatar
OldBlackCat
Posting these Pictures for reference, and anyone researching and wondering what the hell difference between a stock and RiffRaff high flow fitting is....
High Flow Fuel CVD Fitting Set - Riffraff Diesel Performance
install is in theory easy, the back one on the passenger side head is a bugger!!!! the driver side one is on the front and really easy to get to if your also doing the high flow banjo bolts from RiffRaff at the same time...
picture below is of the drivers side head .
Old Apr 27, 2015 | 08:19 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Need your impressions after sir
Old Apr 27, 2015 | 09:24 AM
OldBlackCat
will try, alot is going on in this teardown!
what was thought to be a leaky fuel bowl turned out to be a cracked passenger side fuel line (dreaded passenger side clamp).
while all of this is out i sent the HPOP out to be freshened up along with stopping that oil leak... which in turn allowed me time to order fuel system goodies as a "well... while i got the fuel system torn apart i might as well"
Old Apr 30, 2015 | 04:10 AM
OldBlackCat
updated first post with picture showing the banjo bolt and fuel line check valve delete installed, on the drivers side head behind the bracket for the alternator and power steering pump.
Old Apr 30, 2015 | 07:00 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Making over 500 RWHP is possible on the stock ones. Any improvement in acceleration or power can be traced back to the better power-to-weight ratio because of the fewer number of Benjamins in his wallet weighing him down.
Old Apr 30, 2015 | 08:37 AM
duck fan's Avatar
duck fan
Because racetruck
LOL, you can make 500hp on a stock turbo too, if you feel that you hate things like reliability and common sense.
Old Apr 30, 2015 | 10:32 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yep, been there, done that.
Old May 1, 2015 | 11:36 AM
F250_'s Avatar
F250_
Since this will change the back pressure in the fuel lines downstream of the fuel bowl, might this result in a pressure imbalance and end up needing to use a different spring in the FPR?
Old May 1, 2015 | 10:20 PM
carl2591's Avatar
carl2591
so if the replacement part, the high flow "check valve", appears not to have a check valve inside what is the value of it??
reason for asking is I am looking at replacing the fuel hard lines with 3/8 stainless steel braided lines and AN fittings. The plan is to screw the AN fitting directly into the head eliminating the check valve.
any issue with that.??
How about the banjo bolt replacement.. needed or not??
Old May 1, 2015 | 10:24 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Both a waste - especially the bolts.
Buy new vibra-lok (friggin' trade names) rubber collars for the original fittings, take out the guts of the old ones, and run it.
Old May 2, 2015 | 03:06 AM
jhobbs26's Avatar
jhobbs26
i just swapped my hard lines and check valves with brass 1/8" npt-#4 AN and stainless lines. Pretty straight forward job, removed the factory fittings out of the fuel bowl, removed the check valve fittings from the heads, installed new pipe/AN fittings in head/fuel bowl and attached braided lines. Drove it to work ~ 35 miles one way and back home. SOTP feel, nothing really lol, but i'm 1/2 way closer to going full regulated. All i need is 2 more lines and the regulator.
BTW, these are the lines i used but different lengths.
Goodridge 15 Inch Braided Brake Line with 90 Degree End - Speedway Motors, America's Oldest Speed Shop
After dirt track racing for 13 years i've accumulated a few of these, i've got more but they are straight on both ends, and not sure if it will work cleanly.
carl2591
Aug 28, 2015 03:47 PM
OldBlackCat
15
Apr 30, 2015 04:09 AM
Robbieo11
Jun 20, 2014 09:20 PM
mrblonde108
13
Aug 16, 2012 09:33 PM
powerstrokefever
Aug 29, 2009 04:52 AM
