RiffRaff Banjo Bolts
doing some repairs to my fuel system, and well i got a little carried away with ordering RiffRaff goodies
took some pictures of a stock and RiffRaff banjo bolt side by side, mostly for reference for anyone researching banjo bolts and wondering what the hell the difference is i know i sure was....
http://www.riffraffdiesel.com/riffra...njo-bolt-7-3l/
install was not too hard.... i recommend while replacing the front banjo bolt also doing the fuel High Flow Check Valve Delete from RiffRaff at the same time. just easier with the power steering / alternator bracket out of the way.
Also, the instructions say the easyist way to install the passenger banjo bolt on the back of the head, is by reaching up along the down pipe. well i have mitts for hands, and with the down pipe in there its just too tight to work.
i found taking the passenger fender liner out to be QUICKER! and! you can look right at what for working on.... (mind you my truck is lifted 6" on 35" tires, your mileage may vary)
my mirror is right in the location of the banjo bolt, i am sitting on a 5 gallon bucket while doing this task.
will try, alot is going on in this teardown!
what was thought to be a leaky fuel bowl turned out to be a cracked passenger side fuel line (dreaded passenger side clamp).
while all of this is out i sent the HPOP out to be freshened up along with stopping that oil leak... which in turn allowed me time to order fuel system goodies as a "well... while i got the fuel system torn apart i might as well"
Try a minor plumbing repair in a 90-year-old house! I don't want that tee-shirt again!
[ Imagine black iron natural gas piping that has yellow sulfur crystals coating the entire pipe exterior from the sulfur having permeated the pipe over its 90 years of use. ]
i know clay replied already, but i made a separate thread for the fuel check valve deletes that i installed.
https://www.ford-trucks.com/forums/1...tting-set.html
i made a separate thread with specific wording in the title so when people search the forums or Google this should pop up with pictures.
BTW: thanks clay! awesome parts! i don't even waste my time trying to find them local, i just goto Riffraff strait away
Why bother trying to drill out your stock pot-metal bolts and break them off while reinstalling? Not to mention a larger hole does not necessarily equal more flow, and can create an incredible amount of turbulence that actually reduces flow to less than stock.
We have engineered a high flow fuel bolt using StressProof® Steel that offers the highest flow possible. By combining a patented, high-end steel with precision flow/port testing we have been able to reduce turblence, raise flow, and increase bolt strength all at an economically minded price point.
- Made from Patented StressProof® Steel
- Precision machined low restriction ports
- Viton Oring Leak-Free Seal
- 100% Made in the USA
Again, forgive my ignorance, but what would be the benefit? Is the factory bolt a significant impedance to fuel flow? Im assuming it helps maintain flow/pressure when under load? Would this be beneficial to the average joe or just under high loads for drags or sled pullers? Maybe im just having one of those days, but im not following.... hell i just had a box with the yellow tape arrive today....just what i need is a reason to have another one show up next week.....lol
