Slow starting
Old Apr 26, 2015 | 03:26 PM
dirtman48's Avatar
dirtman48
Slow starting
Ok so I have a 95 7.3 that I have owned for about 6 months now.
I love this truck, has never given me any starting problems until now. I disconnected the batteries to reset the truck because over drive was flashing and the speedo wasn't working, found out it was a fuse that was bad. So after that it has been really slow to start in the mornings 45 degrees. And the glow plugs are new. I got the batteries tested at advance auto. They are both 750 cca batteries. But when the guy tested them when they were connected together, they were 1250cca. But when you disconnect them they are both 750cca. He also tested the starter cable and it's good, same as the alternator. When the truck is off it reads 12.6 on the volt meter and 14.7 when the trucks on. I don't really know where to go from here. Any ideas?
Old Apr 26, 2015 | 03:52 PM
farmert's Avatar
farmert
IIRR the minimum CCAs for batteries size is 850. This may be part of your problem. Are the post and cable ends shinny clean? Also the starter may be getting tired. They tend to wear down after time, and as they age, you don't notice that they are spinning slower, until it is replaced, then the new starter sounds like it is going to spin the engine out of the compartment.
Old Apr 26, 2015 | 04:12 PM
dirtman48's Avatar
dirtman48
I didn't know that. I got a bud that had 850s that I want to put in mine to see if that is the problem. Yeah all the connectors are all shinny tight.
Old Apr 26, 2015 | 06:11 PM
427 fordman's Avatar
427 fordman
Starter may be getting weak.
Old Apr 26, 2015 | 07:16 PM
dirtman48's Avatar
dirtman48
I just cranked my truck up to run to the store and it wouldn't crank the first time I turned the key. I had to crank it twice to for it to crank. I'm pretty sure it's the starter now. What do yall recommend for starters, where to buy them which brands are best for the money?
Old Apr 26, 2015 | 07:28 PM
ReBilld's Avatar
ReBilld
The Super Duty ('99-'02) starters are supposed to be an upgrade and will bolt right up. They are a gear reduction starter, and will probably last longer.
Old Apr 26, 2015 | 07:45 PM
fordpride's Avatar
fordpride
X2^^^^^
Just have to drill out the ring terminal on the small wire.
Old Apr 26, 2015 | 07:48 PM
dirtman48's Avatar
dirtman48
My truck is a 95 will it fit? Even though it the same motor?
Old Apr 26, 2015 | 07:52 PM
ReBilld's Avatar
ReBilld
Yes it will fit. There are only two bolts used on the SD starter, where ours use three, but it will still bolt up.
Old Apr 26, 2015 | 08:53 PM
pilgrimbizket's Avatar
pilgrimbizket
I recently picked one up from auto zone for an 01 and it uses 3 bolts looks like an OBS one to me
Old Apr 26, 2015 | 09:13 PM
fordpride's Avatar
fordpride
You can get a 2 or 3 bolt for the SD
johnboggs21
84
Jan 23, 2010 07:53 PM
amthatiam
Jun 24, 2009 05:21 PM
ghunt
22
Dec 27, 2008 09:13 PM
kaotikedge_111100
21
Sep 29, 2008 07:34 PM
gunwalder
Jan 8, 2004 12:59 PM
