Timing chain Navigator
Old May 16, 2015 | 10:01 AM
alloro's Avatar
alloro
I was also thinking of the O2 sensor.
Old May 16, 2015 | 10:07 AM
Skauber's Avatar
Skauber
Isn't the O2 sensor lower down? Or does it reach all the way up to the head?
Edit: Oh, and isn't the O2 a 4-pin?
Old May 16, 2015 | 10:18 AM
FoxFord33's Avatar
FoxFord33
I haven't seen any of these with a 2 wire O2. It really looks like a fuel injector connector to me, but that code is pretty easy to trace. No codes related to fuel delivery?
EDIT: Never mind, you're still assembling. Reviewed the whole thread.
Old May 16, 2015 | 10:25 AM
Skauber's Avatar
Skauber
I think the knock sensors, the CHT sensor and injectors has quite similar looking connectors, so could be any of those.. An unplugged injector will quickly set a check engine light but an unplugged knock sensor will not set any check engine light. In any case, it doesn't look like he has assembled it enough to turn the ignition on.
Old May 16, 2015 | 10:39 AM
Skauber's Avatar
Skauber
Just checked my shop manual for the '05, the only connector that looks like the one in the picture is the connector for the CHT sensor. I'm holding a CHT sensor in my hands as I'm gonna swap mine out when I have the intake off to replace/repair the IMRC actuator, and it looks like it would connect to the plug shown. The wire colors in the shop manual is different from the ones he said, but it's a different generation so it doesn't surprise me. On mine, there is a short extension harness between the plug in the main engine harness and the plug itself, not sure if they did the same with the 1st gen.
Old May 16, 2015 | 10:40 AM
pdqford's Avatar
pdqford
In post #11 you mentioned "close to driverside head".
In post #14 you mentioned "passenger side head."
I can't find a white connector at the rear of either head on my '02.
Are those pics with the intake manifold off?
Old May 16, 2015 | 10:46 AM
Skauber's Avatar
Skauber
Well, here's a replacement pigtail for the connector to the CHT sensor..
More Information for MOTORCRAFT WPT1120
Old May 16, 2015 | 11:19 AM
alloro's Avatar
alloro
What are the colors (insulation and stripe) of the 2 wires going to the connector?
Old May 16, 2015 | 07:39 PM
pdqford's Avatar
pdqford
Originally Posted by 300zx
the color of the wire looks like brown with green and brown with red.
Could you double check those colors?
Old May 10, 2016 | 12:43 PM
maspain77's Avatar
maspain77
Hello, newbie here. Sorry for bringing up an old thread, but I recently had a lot of trouble with this connector/sensor and thought this might help someone out there stumbling onto this thread while looking for info...
On my 1999 Lincoln Navigator, 5.4L 32V DOHC Intech engine, that white, 2-pin connector on the pics in this thread, connects to the Cylinder Head Temperature Sensor, which is located on the firewall end of the passenger side cylinder head (bank 1). I'd say that's not a sensor you can reach by hand, or using regular tools, as it mounts on a place that is recessed on the head, not even if you remove the intake.
From my research over the internet, on SOHC engines, that same sensor when equipped, goes in the intake valley behind the alternator, and alternator removal will give you access to it.
Hope this helps...
-Sam.
chambejp
Jul 4, 2016 10:33 AM
kidzstang
1997 - 2003 F150
Mar 4, 2012 07:58 AM
Jim88554
1997 - 2003 F150
Nov 17, 2008 05:39 AM
Green Streak
Apr 5, 2007 08:33 AM
urif250
Nov 30, 2002 02:23 PM
