disconnected wires?
Old Apr 24, 2015 | 08:16 PM
Haywire-Powerstroke's Avatar
Haywire-Powerstroke
disconnected wires?
Well I found two wires while I was under the hood the other day that are not connected at all, just laying there. These two wires are right next to the fuel bowl and I presume they should be plugged in somewhere. Any help as to what these wires do and where they go would be greatly appreciated.
I think I found where the hex shaped plug is supposed to be at on the side of the fuel bowl but can't hardly seem to get it plugged in with the position it's in.
Old Apr 24, 2015 | 08:31 PM
fordman67's Avatar
fordman67
The flat bladed one is fuel heater.leave it unhooked.the other is for fuel filter restriction sensor.yours is missing.I wouldn't worry bout it.just keep fuel filter serviced properly.tape them up and forget them.
Old Apr 24, 2015 | 09:14 PM
Haywire-Powerstroke
alright so the one is just to tell me when i need to change my fuel filter, which i can do myself no big deal but wouldnt i want the fuel heater working though?
Old Apr 24, 2015 | 09:25 PM
OldBlack4x4's Avatar
OldBlack4x4
It is possibly unhooked due to a shorted fuel heater which would blow a fuse and essentially shut the truck down and cause a no start issue. Better to just leave it off wrap it up and forget it
Old Apr 24, 2015 | 09:26 PM
fordpride's Avatar
fordpride
The fuel heater isn't a fuel heater. It's s fuel filter warmer. It's job is to warm the filter to expand the junk on the filter to let fuel flow better. If you keep it serviced properly you won't have a issue
Old Apr 24, 2015 | 09:27 PM
oldbird1965's Avatar
oldbird1965
Most fuel heater elements break and short out. Its connected to the same fuse the PCM is connected and if the heater element shorts out it will blow the fuse and kill the truck.
edit: two beat me, LOL
Old Apr 24, 2015 | 09:30 PM
Haywire-Powerstroke
what if i replaced the fuel heater? if it had a short would that fix the problem
Old Apr 24, 2015 | 09:33 PM
Haywire-Powerstroke
ok well then knowing that i think ill just tape them and forget them
Old Apr 25, 2015 | 07:33 AM
tjc transport's Avatar
tjc transport
i ain't rite
i would not bother with the heater. mine has been disconnected for over 24 years and not once have i had a problem, even in temps under -5F
Old Apr 27, 2015 | 09:52 AM
madpogue's Avatar
madpogue
^^^^^ +1; there are fellas way north of Marlboro who have disconnected the fuel heater. It was designed into the system at a time when diesel fuel was not nearly as stable in the cold as it is now. Be sure to use winter blend fuel in winter, throw in some anti-gel additive for good measure, maintain the fuel filter, and you're golden.
LittleLucy
Mar 30, 2019 07:23 AM
Cmg66999
Dec 14, 2018 07:16 AM
RigCity
Jun 15, 2018 11:16 PM
2005f-150
Aug 14, 2010 11:27 AM
osb
Jan 18, 2010 04:57 PM
