No power
Old Apr 24, 2015 | 12:27 AM
Motosk813's Avatar
Motosk813
No power
So I have a 1985 f250 with the 460, I've been working on it for the past few days and I have a problem. I get absolutely no power to anything unless I start the truck from the engine bay off the starting solenoid, after I do that the starter keeps cranking when the motor fires and then I get power to everything, I have yet to figure this out anyone have any idea why this is happening?
Old Apr 24, 2015 | 06:17 AM
1986F150six's Avatar
1986F150six
Can you post a photo of the starter solenoid and its associated wiring?
Welcome to the forum!
Old Apr 24, 2015 | 07:46 AM
Gary Lewis's Avatar
Gary Lewis
Yes, welcome to the forum!
David is requesting the pic because he suspects your truck is not wired correctly. And I think he's right.
Old Apr 24, 2015 | 01:07 PM
Motosk813's Avatar
Motosk813
I'm not getting power to the red wire and the one with the blue
Old Apr 24, 2015 | 02:14 PM
Gary Lewis's Avatar
Gary Lewis
It looks to me like you have one fusible link in the wrong place as it is on the starter side of the solenoid. I believe the wire in the top right corner of the pic, the one with the orange flag, should be on the other main lug of the solenoid - the one on the left side in the pic.
Note in the attached wiring diagram that the fusible links go on the battery side of the solenoid. However, that's for an '81 truck so it is possible that yours is supposed to have some on the other side - but I don't think so. If so, they would only have power during cranking, which makes no sense.
Old Apr 24, 2015 | 02:26 PM
Motosk813's Avatar
Motosk813
okay thank you I'll try that and see if it works, so there is on,y suppose to be one wire on the starter side?
Old Apr 24, 2015 | 02:55 PM
ctubutis's Avatar
ctubutis
The only one that belongs on the starter side is the real thick one going to the starter motor.
Carmax
13
Nov 17, 2015 08:42 AM
78orBUST
Electrical Systems/Wiring
Sep 12, 2011 11:17 AM
gearhead351
Oct 12, 2008 07:56 PM
sooline1
Oct 31, 2006 05:25 PM
88broncofan
1978 - 1996 Big Bronco
Mar 4, 2004 12:05 AM
