cold idle speed
Old Apr 23, 2015 | 06:19 PM
fordguy98's Avatar
fordguy98
cold idle speed
OK so I'm having trouble with the idle speed on my 79 f150 with a 460. when i first start the engine when its cold and let off of the gas pedal it dies out but if i keep my foot on the pedal just a little bit it'll stay running then when it warms up i can let off of the pedal and it will idle just fine. what could my problem be??????? i read somewhere that it could be a bad accelerator pump. if it helps any I'm running a holley 4180 4bbl carb.
Old Apr 23, 2015 | 08:10 PM
notthemaniusedtobe's Avatar
notthemaniusedtobe
Sounds suspiciously like a faulty choke if it's only happening while it's cold....
Old Apr 23, 2015 | 08:43 PM
swall's Avatar
swall
x2 or just a slight adjustment is needed.
Old Apr 23, 2015 | 09:38 PM
Blue and White's Avatar
Blue and White
Mine will do the same thing (400) if I peddle it. What I do instead is pump once before starting to set choke/fast idle and give it a shot of fuel. Then start it without touching the gas. Usually works. Let it run on fast idle for a minute or so then use the peddle.
Old Apr 24, 2015 | 12:10 AM
AK FORD GUY's Avatar
AK FORD GUY
Defiantly sounds like a choke / high idle issue.
I wish I could get mine figured out, it always requires two pumps to start.
Old Apr 24, 2015 | 10:48 AM
fordguy98's Avatar
fordguy98
whens cold it wont idle {and i do think that my electric choke might be sticking a little bit open} the when it warms up it idles just a little bit fast for my taste. like if i take my foot off of the gas when I'm out driving it'll run about 10 mph just by the idle speed but if i slow the idle speed down then it dont run quite right could this be a carb related problem
Old Apr 24, 2015 | 10:52 AM
fordguy98's Avatar
fordguy98
oh i do have to pump my pedal to get to start up when its cold
Old Apr 24, 2015 | 03:42 PM
bkaul's Avatar
bkaul
If you have to pump your pedal to start in addition to not having cold idle, then your choke definitely isn't adjusted properly. It should be one press to the floor to set the choke, then let off the throttle and crank right up, when everything's properly adjusted.
Old Apr 26, 2015 | 03:57 PM
Ozzie H.'s Avatar
Ozzie H.
Here's another vote for the choke. That 4180 has a fast idle cam which should hold the throttle a bit more open when the engine is cold if it's working correctly. An adjustment may be needed.
Old Apr 26, 2015 | 04:49 PM
BenOakley's Avatar
BenOakley
I have an edelbrock 1405, similar issue. What would be the best way to adjust or determine if you're doing it right? I'm no expert with these, and it was put on by a previous owner who lived in California. Picture for reference...
Old Apr 26, 2015 | 05:23 PM
fordguy98's Avatar
fordguy98
how do i adjust the fast idle cam?
Old Apr 26, 2015 | 09:21 PM
Ozzie H.'s Avatar
Ozzie H.
There should be a screw at the fast idle cam. Study this site:
How To Adjust The Electric Choke On A Holley Four-Barrel Carburetor - Blogs - Holley Performance Products Forums
The second part about setting the idle should do what you need.
Old Apr 27, 2015 | 06:09 PM
fordguy98's Avatar
fordguy98
thanks for the link!
daveinva
Nov 8, 2018 08:15 AM
fordguy98
Apr 26, 2015 10:22 PM
yankeerebel
Dec 13, 2010 12:20 PM
marioc956
Apr 6, 2007 07:54 PM
ford429cu
Nov 29, 2002 12:33 AM
