Jumping at 45 mph
Old Apr 23, 2015 | 06:12 PM
LEWIS2001's Avatar
LEWIS2001
Jumping at 45 mph
Hello I am new to the site and want to say hello first of all. Now for the problem I am having. I have a 2001 F150 super crew 4x4 Lariat,the problem I am having is when the truck hits 45 mpg and shifts into higher gear I get a bad jumping or missing. I can put the overdrive in the off position and it gets a lot better but does not fix the problem completely. I was wondering if anyone else has heard of or experienced this. I have changed the fuel filter and this helped some. I have also checked spark plug coils and have even had codes run on it that just showed my ABS has a problem which was a broken sensor wire. Any help with this would be GREATLY appreciated.
Old Apr 24, 2015 | 07:43 AM
projectSHO89's Avatar
projectSHO89
Common, low-grade misfire, usually due to a bad COP.
Many dozens of prior threads on the all-too-common issue.
Old Apr 24, 2015 | 03:09 PM
LEWIS2001's Avatar
LEWIS2001
RE jumping at 45 mph
Thanks for the reply can you point me in the right direction as far as the other threads are concerned on this issue
Old Apr 24, 2015 | 03:50 PM
projectSHO89
In the box above that says "Search", enter "Misfire".
IndyFan
1997 - 2003 F150
16
Jan 2, 2016 06:34 PM
NJBass
Oct 12, 2011 11:07 AM
Bosaw
1997 - 2003 F150
May 11, 2007 09:18 PM
danielharr79
1997 - 2003 F150
Apr 25, 2006 12:16 AM
levcar
1997 - 2003 F150
Aug 9, 2004 07:52 PM
