Some quick questions
Old Apr 22, 2015 | 09:43 AM
199673Nick's Avatar
199673Nick
Question Some quick questions
I have a 1996 7.3l f250 long bed. It is a 2wd and has some 4.10 gears in the rear and a 5spd manual or 4spd w/ "overdrive". Anyways, it had a towing flywheel with the springs in it to take up some of the load, but I don't do anymore towing so I am going to replace the transmission clutch and pressure plate along with a solid one piece flywheel. Curious about how the clutch will react. Other than that it is getting repainted and I was wondering about the exhaust. I want a turbo back of some sort and am wondering on the size of the pipe. 4" or 5"? and if so will I have to go with a tuner?? and possible an intake. Other than that, what epa bs does this truck have?? Does it have an egr and dpf?? let me know!!! I'm new to the whole thread scene as well.
Old Apr 22, 2015 | 10:14 AM
rugermack's Avatar
rugermack
I think your clutch has springs, not your flywheel.
Old Apr 22, 2015 | 10:16 AM
rugermack's Avatar
rugermack
Clutch friction disc
Old Apr 22, 2015 | 09:31 PM
199673Nick's Avatar
199673Nick
You may be right!! Excuse my ignorance on the subject
Old Apr 22, 2015 | 09:53 PM
krooser's Avatar
krooser
99.9% of all street driven vehicles use a sprung hub on the clutch disc to make clutch engagement smoother. Race cars usually use a solid clutch plate… you don't want that. Stick with the sprung hub.
A 96 7.3 will have an EGR valve IIRC but it will not have a DPF.
Old Apr 23, 2015 | 09:30 AM
EPNCSU2006's Avatar
EPNCSU2006
Looks like you are asking about swapping a dual mass flywheel for a single mass flywheel. You might want to visit the diesel section as they may be able to give you some more information, pros/cons, etc.
Tomahak
Nov 15, 2013 07:11 PM
79f-250custom
Jul 31, 2009 03:06 PM
harley dude
Aug 13, 2008 02:46 PM
kooper909
15
Apr 11, 2008 09:59 AM
GA Strokin
Jun 14, 2006 08:24 PM
