need help finding a part
Old Apr 22, 2015 | 07:41 AM
jmuma2011's Avatar
jmuma2011
I have a 1997 F350 7.5L with the E4OD transmission. I'm looking for the connector that connects to the top of the transmission shift solenoid pack.
Old Apr 22, 2015 | 10:40 AM
jmuma2011's Avatar
jmuma2011
well I just went to the Ford Dealer and they said they discontinued the part. And I also went to the Junk yard and atleast at that one they said they dont have any. they just drop the transmissions and cut an pull all the wires and throw them away.
Old Apr 22, 2015 | 10:59 AM
jmuma2011's Avatar
jmuma2011
found a replacement part on ebay
Old Apr 22, 2015 | 02:48 PM
cbakker's Avatar
cbakker
Was your old harness bad, or was the plug just crushed/cracked?
Sent from my iPad using IB AutoGroup
Old Apr 22, 2015 | 03:03 PM
jmuma2011's Avatar
jmuma2011
the old one was cracked and kept vibrating loose causing it not to shift right
Old Apr 22, 2015 | 03:40 PM
cbakker's Avatar
cbakker
I hope you found a matching one. You aren't getting and ATF leak to the harness are you? That will cause untimely/no shifts also. I would have ziptied the plugs together and ran with it, but it sounds like you are going about it the right way.
Old Apr 22, 2015 | 05:27 PM
jmuma2011's Avatar
jmuma2011
yeah unfortunately there was some ATF on the harness witch i know is a sign that i need a new solenoid so ill prob. be changing that out soon. But yeah I found the harness on ebay for $30 so I figured I might as well do it the right way.
trumsey07
40
May 20, 2021 08:53 PM
mikekerr
Jul 28, 2019 06:52 PM
nick2064
Apr 4, 2017 12:31 PM
nick2064
Apr 3, 2017 05:22 PM
Encho
May 28, 2016 04:37 PM
