e4od wiring
Old Jan 19, 2014 | 06:19 PM
trumsey07's Avatar
trumsey07
e4od wiring
i just bought a 97 f250 5.8 e4od.the trucks transmission was bad so i replaced it with one from a 94 f250 same motor.the only difference between the trannys are the solenoid plugs.does anybody know how i can wire the 94s plug into the 97s wireing harness? thank for the help.
Old Jan 19, 2014 | 07:24 PM
rla2005's Avatar
rla2005
You need to swap the solenoid pack from the '97 into the '94 donor transmission. There are internal electrical differences between the two packs.
Also need to ask how you determined the original transmission was bad? More than once a perfectly good one was replaced because of a bad sensor.
Old Jan 19, 2014 | 09:45 PM
trumsey07's Avatar
trumsey07
i got the truck off of a buddy who said it slipped,so we dropped the pan and the magnet was covered and the filter was nothing but metal shavings,so there is no way to splice the plug ino the 97s plug?
Old Jan 19, 2014 | 10:34 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Old Jan 20, 2014 | 01:47 AM
Lead Head's Avatar
Lead Head
You can use a 94 solenoid pack on a 95+ truck if you use the correct connector. You just can't use a 95+ transmission on a 94 or earlier truck.
Old Jan 20, 2014 | 09:32 AM
rla2005's Avatar
rla2005
As Lead Head is alluding to you can use an older style solenoid pack connector from a '94 and older donor but electrically the 95+ solenoid packs are different. So the easiest solution, which many use, is to swap the solenoid pack from the 97 onto the 94 donor transmission.
Old Jan 20, 2014 | 10:15 AM
Lead Head's Avatar
Lead Head
The only thing that is different, is that the protection diodes moved from the solenoid pack to the ECU in 95+ systems. So you can use the earlier solenoid pack with late model ECUs - you just have redundant diodes.
Old Jan 20, 2014 | 06:20 PM
trumsey07's Avatar
trumsey07
so heres where i am at. the original 97 transmissions solenoid was destroyed and i do have the connector from the donor 94 transmission. both wires use the same amount of wires and all but 3 wires are the same color code. has anyone just swapped plugs and if so what combo works
Old Jan 20, 2014 | 07:15 PM
rla2005's Avatar
rla2005
The wire colors and functions should have remained the same from at least 1992 to '96/97 for the solenoid pack connector (C1048). I verified using my Ford EVTM manual. 1994 and 1997 models match this diagram:
Old Jan 22, 2014 | 05:24 PM
trumsey07's Avatar
trumsey07
i swapped plugs today,and the 97s solenoid plug had 2 solid red wire connectors and the 94s plug has a solid red wire and a white with red striped wire. i connected the solid red to.the white with red stripe wire and nothing,i then tried swapping them with the other red wire and still no shift.the truck will manually go through all the gears but overdrive.if i put the truck in drive it will automatically go to second gear.all of the 9 wires are hooked up to the same colors bit the 2 wires mentioned above.im lost now
Old Jan 22, 2014 | 06:04 PM
Lead Head's Avatar
Lead Head
Old Jan 22, 2014 | 06:36 PM
FORDF250HDXLT
here is the 89-94 (pre-95 old style)
oops mlps.nevermind.i don't have a snap of the s-plug.
http://www.supermotors.net/getfile/8...-connector.jpg
what year is that there led?^ oh its the new 95+
he needs an old one (as do i for my album.hmmm)
Old Jan 22, 2014 | 06:40 PM
subford's Avatar
subford
Maybe these diagrams will help:
1996 plug:
Old Jan 22, 2014 | 06:51 PM
FORDF250HDXLT
oh heck ya.that'll be some handy to have.thats like a super diagram. thanxs sub!
Old Jan 26, 2014 | 08:07 PM
trumsey07's Avatar
trumsey07
ok i got to the wiring today and i was able to splice the 94s plug into the 97s harness.everything works great thanks for all the help.the diagrams really helped
