Electric brake controller
Old May 13, 2015 | 12:58 PM
A Rodder's Avatar
A Rodder
Pictures worth a thousand words!
I've often used a flat tipped screwdriver and popped the oem plug off its mounting bracket.
It frees up an inch or two of wiring and allows you to pull it towards you a little. It can make it easier to plug into it.
Old May 14, 2015 | 06:09 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by A Rodder
Flip the lid up on the 7 way.
With the ground hooked up on your test light, ... If they don't function let me know.
Thanks, everything checks good.
I hooked up the trailer and all looks good, too.
Our trailer came with a square metal electrical box for the trailer cable connections mounted in front of the batteries. It was a standard electrical box and everything inside was rusting. I cut all that out and mounted a rectangular plastic connection box under the trailer, rewired and labelled everything. Added 4 individual wires for the brakes and split loomed everything. Also, put in a standoff 12v post in a box underneath to connect all the high amp 12v circuits away from the battery.
I have one more connection to install - the 12v charge line from the car 7-way.
If I understand this correctly -
1. The car 12v charge line is connected to the trailer battery and the 12v power converter.
2. When I am towing the alternator is charging the trailer battery.
3. When I am camping with ground power the 12v power converter is charging the trailer battery. But, if the 7-way is still connected the car battery will not be getting charged because the car relay has disconnected it.
Old May 14, 2015 | 07:17 PM
A Rodder's Avatar
A Rodder
Yes on all accounts buy disconnect the truck from trailer at campground just for safety sake.
Ridenred333
Jul 20, 2012 09:50 PM
CruiserClass
Jun 7, 2010 09:41 PM
wreckerboy
45
Oct 2, 2005 07:15 AM
CC'sDad
Feb 25, 2005 06:33 AM
leroys4wd
1997 - 2003 F150
Jul 13, 2004 12:41 AM
