Emergency Brake Cable Broke: How Fix?
1999 F-250
How does one replace the emergency brake cable? Are there any tricks or tips to it?
The cable in the '99 F-250 I recently bought broke.
The cable was sticking when I got the truck. I like to use the emergency brake every time I park. The previous owner(s) didn't use the emergency brake and the cable had frozen up.
I tried using it every time I parked. I could tell it was frozen, but I was hoping it would loosen up. It held a little bit when I used it; but soon it just broke.
1999 F-250
Right- there are 4 cables to the setup- 3 are jacketed and one is bare:
1) jacketed cable from pedal to about the front of the door.
2) bare cable from there to a little before the rear wheel well
3) jacketed cable to the LR brake
4) jacketed cable to the RR brake
The bare cable needs to match your configuration, such as single cab, extended short, extended long, crew short, crew long or Excursion. This seems to be the one that most often breaks, and if it is broken, TEST THE OTHERS for smooth operation through their jackets as well.
WindBlue72
05-08-2019 11:55 AM
UP_There
08-02-2016 09:04 AM
400944
04-20-2008 01:44 PM
