Cruise control steering wheel light?
Old Jul 26, 2003 | 10:29 PM
blackvettec5's Avatar
blackvettec5
This is fo a 2000 explorer XLT. I searched old posts and found the part number for the bulb. Replacing that isn't the problem. However, not I can't get the switch box cover to go back on. Its the one for on/off on the left side of the steering wheel. Any tricks to get it back on?
Thanks in advance.
Old Jul 28, 2003 | 05:03 AM
reberhardt's Avatar
reberhardt
Remove the switch from the steering wheel. To remove the switch, you'll need to disconnect your battery and then remove the two screws on each side of the steering wheel to slide the air-bag module out. Once you have the air-bag out of the way, the cruise switch can be easily removed by removing the two screws holding it in. Once you do it, you'll wonder why you didn't try replacing the bulb this way in the first place. It should take you less than 10 minutes, start to finish.
Old Jul 28, 2003 | 05:55 AM
Torque1st's Avatar
Torque1st
Posting Legend
Be caeful around the air bag, those are bombs that can go off easily.
Old Jul 28, 2003 | 03:40 PM
reberhardt's Avatar
reberhardt
And as long as he follows the procedure as I've described his "bomb" won't go off. Here is the actual procedure (minus the pictures):
Driver's Side
REMOVAL
Remove the battery cables.
1 Remove the battery ground cable.
2 Remove the battery to starter relay cable and wait one minute for the backup power supply to be depleted.
NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
Remove the driver side air bag module. NOTE: Make sure the wheels are in the straight-ahead position.
1 Remove the two back cover plugs.
2 Remove the two driver side air bag module screws.
3 Disconnect the air bag sliding contact electrical connector.
4 Remove the driver side air bag module.
If the driver side air bag module is diagnosed as faulty, dispose of the air bag.
INSTALLATION
To install, reverse the removal procedure.
Old Jul 28, 2003 | 04:11 PM
blackvettec5
Little question. Are the screws covered by round tabs on the left and right side of the steering wheel?
Old Jul 28, 2003 | 10:04 PM
CobraXP's Avatar
CobraXP
Yes they are. You have to pry those out to get ot the screws...
Old Oct 29, 2003 | 09:31 AM
terestron's Avatar
terestron
Question Bulb part number? where to purchase?
OK what is the bulb type? Part Number? anywhere for pictures?
Please help us out!!!!
Thanks!
Old Oct 29, 2003 | 09:48 AM
CobraXP's Avatar
CobraXP
I think this is reberhardt's pic (I borrowed it for the numbers myself )
Old Oct 29, 2003 | 09:49 AM
terestron's Avatar
terestron
Question
And these can be purchased where? Ford Dealer? Auto Zone?
Old Oct 29, 2003 | 10:05 AM
CobraXP's Avatar
CobraXP
I've never looked at Auto Zone - but your local dealer can get them...
1969 Ranger 4x4 390
16
Feb 21, 2017 02:06 AM
sixseven
2015 - 2020 F150
Nov 20, 2015 05:12 PM
justplumducky
Jul 21, 2015 07:56 PM
HillBillyBuddha
Jul 5, 2015 02:10 PM
JStan
Oct 17, 2003 06:23 PM
