Steering problem
Steering problem
The other day when driving around in the back country I noticed that the power steering was only working when turning right and not when turning left. On my way back to my house the steering wheel pinned full right and would only move back if the engine was off, in order to get back I removed the power steering belt. It turned both ways, but not without considerable effort and some banging noises. I went under and nothing appeared to be damaged. I don't know What's going on, any help would be appreciated.
With Power Assist, the manual steering box is used, because it has nothing to do with P/S
Pic: F250 4WD Power Assist P/S .. Control valve (2 different types), shown as 3A730, hydraulic cylinder shown as 3A540.
I know, f-100
If the system includes a hydraulic cylinder and a control valve, it's Power Assist P/S optional on 1973/77 F250 4WD's.
on
Now that we have the ps id'ed, did you pull the dipstick and check fluid level? Is the fluid bright pink, or is it brown and smells burnt? Or is it totally drained of fluid? No hoses leaking? Then it seems it could be a mechanical problem with the ps box. Put the front end on jack stands, start the engine after replacing the belt, and turn it from side to side to try to replicate the problem. If it is mechanical, get a new remanufactured box from Red Head Steering as these are the best out there.
