installing intake manifold
Old Jul 1, 2015 | 09:12 PM
PA74F250's Avatar
PA74F250
Originally Posted by tbm3fan
Where else? Amazon
Amazon.com: MOTORCRAFT TA31: Automotive
The cork end seals with adhesive look tempting but they may vary a bit in thickness. I tried them out and then laid the intake for a trial fit. The intake sat too high and may not have come down enough when torquing. That might leave me a water port gap and definitely a mis-alignment where the head and intake meet. So I used the TA-31.
Good luck as I have had three failures already and will be going for #4 to seal the intake.
I agree the adhesive is very tempting and is why I used it once I saw how it stuck. Something doesn't sound right you keep having leaks. I shoulda measured the cork just to see how consistant it is. If I remember right I think the China walls are supposed to have like a .070 gap to seal right.
I actually put 2 intakes on in the last 2 weeks using that sticky cork. Normally I always go for the permatex.
Old Jul 13, 2015 | 08:29 PM
wcpc4's Avatar
wcpc4
cork end gaskets
Throw the cork gaskets away. No matter how you glue them down they WILL shrink and slip out. One alternative to sealer for the gasket, The Right Stuff by Permatex. This stuff is fantastic. Very strong and flexible. Skims in about 2 minutes and sets up in about an hour. You can return the engine back to service without having to wait like most other sealers.
mercury dave
Sep 4, 2009 06:35 AM
ironhead86
Jan 13, 2009 04:12 PM
asmith6
Nov 30, 2007 09:35 PM
Nev. Bronco
Feb 26, 2005 10:38 PM
76 F250 4X4
Sep 21, 2004 06:50 AM
