390 Steetmaster intake installation
Old Sep 3, 2009 | 10:18 PM
mercury dave's Avatar
mercury dave
I will be installing this manifold on my 390 soon. What type of gaskets and gasket sealer do you guys recomend? Should I use the stock cork end gaskets or replace with some type of silicon sealer? Any opinons will be helpfull. Thanks.
Old Sep 4, 2009 | 06:29 AM
OrangeJuice's Avatar
OrangeJuice
I used Fel-Pro intake gaskets and for a gasket maker I highly recomend using Right Stuff. I've used this on three engines and never had it blow-out or leak. Do not use the cork gaskets, they will dry up and split, crack and leak causing you to rework your intake. What you might want to do is set the intake on the block with the intake gaskets in place. That way you can see the gap on the front and back to fill. Just apply a thick bead making sure to get the corners real good. It comes in an aresol can like cheese whiz. One can should do it.
Good Luck
Old Sep 4, 2009 | 06:35 AM
OrangeJuice
Oh, almost forgot. When you torque your intake down, you should see a little squeeze-out of gasket maker on the front and back. This will tell you that you've applied enough to fill the gap.
