Temp difference
Old Apr 20, 2015 | 03:45 PM
Aune163rd's Avatar
Aune163rd
Temp difference
My oil is running about anywhere from 4-15 degrees hotter than my coolant. Running on flat ground @ 75 mph. It's about 8-12. I know it's got a Napa cap and filter. I'm planning on changing it to a motorcraft here soon. I just wanna know if I should have the engine flushed both in the oil and coolant.
Old Apr 20, 2015 | 04:12 PM
npccpartsman's Avatar
npccpartsman
The true test is running at a steady 65 mph for 15 or 20 miles after the engine is GOOD AND HEAT SOAKED with NO LOAD being pulled. If you have <15* difference you're in specification. And it really won't be accurate until you get the correct oil filter cap back on.
Old Apr 20, 2015 | 04:37 PM
69cj's Avatar
69cj
You also would only do a coolant, chemical, flush if you were changing the oil cooler. You could do a drain and refill with a 50/50 mix of new coolant if you don't know the age and mileage of what's in it now. If staying stock you would use either Ford premium Gold or Zerex G05. They are the same. You would not do an oil flush. If changing the filter and cap back to stock, highly recommended, I'd do an oil change then.
Old Apr 20, 2015 | 04:40 PM
WatsonR's Avatar
WatsonR
After that if your still pretty high, then a chemical flush of the coolant and then an oil cooler change. No flush of the oil and since your in there, maybe an EGR cooler as well....
Pull the EGR valve and see if its wet inside, if so, then an EGR delete or cooler would be needed also before its to late and it ruptures.
Old Apr 20, 2015 | 04:42 PM
69cj's Avatar
69cj
Randy, He's still in spec. I wouldn't be tempting fate with the chemical flush just yet.
Old Apr 20, 2015 | 05:10 PM
WatsonR's Avatar
WatsonR
It's like impending doom... some guys are just a little head of the game, like me.
If you flush the coolant with chemicals, you will be doing an oil cooler. 4-15 isn't bad, but after doing the 65mph test and it's still high (15 or more), start saving.
That sounds better....
Old Apr 20, 2015 | 05:25 PM
Aune163rd's Avatar
Aune163rd
I did the test. It hangs around 9-12* difference. Will do an oil change tomOrrow and report back.
Old Apr 20, 2015 | 05:28 PM
WatsonR's Avatar
WatsonR
Been through Missoula may times, nice place!
Don't forget that cap and filter.
Old Apr 21, 2015 | 01:15 PM
Aune163rd's Avatar
Aune163rd
So I changed the oil. Damn that's expensive. No change in the temp difference. Running 65 for 17 miles it held an 11* difference. Turns out that my aftermarket warranty is gonna pay to fix it. Gionna do a bulletproof egr cooler and whAtnot while the mechanic is in there.
Old Apr 21, 2015 | 01:19 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
11 degree difference isn't that bad.
The true test is to watch the temps over time. If you're at 11 for a year and then all of a sudden it jumps to 15 then do the cooler.
It could hold 11 for the next 100,000 miles.
Josh
Old Apr 21, 2015 | 03:03 PM
Per4mance's Avatar
Per4mance
I'd put a coolant filter in if it's not all ready there............just saying
Old Apr 21, 2015 | 07:27 PM
tracyclifton's Avatar
tracyclifton
Mine stayed at about 11-13 degrees for around 2 years. It was the second oil cooler. When the HPOP went out I changed the oil cooler again and it runs around 6-8 degrees now. If the HPOP had not gone out, I had decided not to change the oil cooler until it constantly ran 15 or higher. By the way, when it went out the first time, before I had gauges, the receipt from Ford said it was running 39 degrees above the coolant.
smacDiesel
Nov 29, 2013 05:06 PM
mstiles19
Apr 9, 2012 09:56 PM
6.0f350newb
Dec 28, 2010 09:41 PM
Race8100
Nov 29, 2010 11:53 AM
Dyllan78
Jun 10, 2010 08:23 PM
