I have a question for you. Repairing a '91 460 with an intermittent starting issue. At first I pulled the cap and rotor and found tons of corrosion and gunk so I replaced plugs wires cap rotor and boom. Started right up. Issue persisted however. When it won't start there is no spark coming from the coil. My question is given that it is an intermittent issue. Would this be a pip problem or should I be looking elsewhere. Furthermore how do I diagnose a pip issue when the truck does want to start. Is there a voltage range I should be looking for. When I connect my voltmeter to the pip based on subfords writeup I get 2.5v to 5v alternating.
Of course when I want to diagnose it the damn thing won't act up. Soon as I hand it back its gonna go wonky again.
That is not normally how a PIP sensor goes bad.
A bad one will never start the engine or it will always start the engine and the engine will quit down the road about the same distance each time. A bad PIP sensor will almost always set a code in the computers CM.
If it does not have a remote mounted ICM then I would replace it. But it is very hard to find out why it will not start sometimes if you never have it do it while you are working on it.
It could also be a bad computer as we have seen the computer do this also with bad capacitors in it or could even be a bad Ignition coil or Ignition switch.
Not if it does not have the problem when he gets his hands on the truck.
But yes I have the tester with me in my tool box so if I need it I can test one:
subford ... your tester looks like something that is worthy of a sticky .
can i assume that a) the connector you are using is a salvaged connector that matches the one coming from the distributor and b) failure of the led to light up during cranking indicates a bad pip ?
also, does it have to be an LED or will any 12v lamp do the job ?
also, do the numbers 16 .. 48 ... etc. have any significance for testing purposes ?
