390-445 build up.
Old Apr 26, 2015 | 07:25 PM
  #31
PA74F250's Avatar
PA74F250
I dug my paper out of the trash that came with the rings today and I see what your saying. I'm kinda afraid of mine the way it is now and might end up buying another set of rings and just grind a new 2nd ring for each. It sucks because normally I woulda just followed the directions but instead I called and asked for advice. I have a feeling I got a recipe for a race motor. I really don't want this thing sucking oil.
Old Apr 27, 2015 | 03:10 PM
  #32
Fellenz's Avatar
Fellenz
Originally Posted by PA74F250
Haha on the circlips those things seriously suck don't they!
Four hands, three hours, every word in the book and a couple homemade bandaids later...those snappy screwdrivers sure like to go through fingertips when your patience loses to common sense.
Old Apr 27, 2015 | 04:41 PM
  #33
PA74F250's Avatar
PA74F250
Yea that sounds about right. I cut myself bad twice trying to do it myself.
On another note I talked to Barry today to verify my ring gaps. He insists that I did do it correctly. He said that normally all mfg do like the 2nd gap tighter. His theory is that there is slight pressure between the top and 2nd ring. With the increased gap it helps get rid of that. He told me even if I ground the 2nd ring to .040 it still wouldn't suck oil. So I guess I'll leave it right where it is.
Old Apr 27, 2015 | 08:48 PM
  #34
Fellenz's Avatar
Fellenz
I wouldn't worry about it none.
Like he said, a couple thousanths isn't going to suck oil at all. Can't say I follow his logic though, what the hell..he knows more than I do; trust the guy.
Old Apr 27, 2015 | 09:25 PM
  #35
PA74F250's Avatar
PA74F250
Yea that's what I'm going to do. He seemed very certain that it was the thing to do.
Old Apr 28, 2015 | 12:16 AM
  #36
rockittsled's Avatar
rockittsled
What the theory behind that is that what pressure bleeds past the top ring can cause the top and/or second ring to flutter because it cant get past the second ring fast enough with a smaller gap than the top ring gap. Some piston manufacturers are putting multi grooves on the piston between the top and second ring lands on that same idea of relieving pressure between the rings
Old Apr 28, 2015 | 09:33 PM
  #37
Fellenz's Avatar
Fellenz
Interesting logic!
Old Apr 30, 2015 | 07:49 PM
  #38
Fellenz's Avatar
Fellenz
Short block assembled!
Have an issue though..
Crank is in and turns nice torqued down. Pistons in and had the friction that I would expect from new rings, however when I torque the rod caps down, it effectively siezes the assembly. The journals look as they should when I pulled caps back off to inspect. The caps had to be massaged on though with a rubber mallet, after both rods were in place but nothing that raised a flag for me.
I did use a liberal amount of assembly lube though, and I'm wondering if too much could cause this situation.
Again it turns fine with the caps finger tight, and it doesn't feel grindy at all, just progressively gets tighter as I squeeze down the caps.
Could I be on to something here? Is too much, or too heavy a lube a possible cause?
Old Apr 30, 2015 | 09:59 PM
  #39
hiball3985's Avatar
hiball3985
Too much lube could cause that but I would get some Plastigauge and check the clearance to be safe. Or mic the crank and check what bearing size is on the back of the bearing.
Old Apr 30, 2015 | 10:01 PM
  #40
Fellenz's Avatar
Fellenz
I will be doing that also, just ran out of time and didn't have the proper measuring tools on hand at the time. Fingers crossed on the lube.
Old May 1, 2015 | 07:53 AM
  #41
PA74F250's Avatar
PA74F250
I don't believe lube is your problem it's just not normal. What were your bearing clearances on the rods? Plastigauge will get you close but really should have been checked with a dial bore gauge. Are you positive you don't have a rod or rods on upside down with the wrong side facing the crank chamfer?
If all is correct it could be something as simple as a piece of lint between the bearing and the rod. The smallest piece of junk could make all the difference.
Old May 1, 2015 | 09:22 AM
  #42
Fellenz's Avatar
Fellenz
I was under the assumption that was all checked because the boxes came opened and all the bolts were quite snug when I got them, unless they come that way factory. I'm going to disassemble and plastigage it tonight and triple check everything.
All rods should have bearing keys facing outward correct? If I have a backwards rod I'm going to throw a fit getting those clips out.
Old May 1, 2015 | 10:33 AM
  #43
PA74F250's Avatar
PA74F250
The bolts are snug becaue they are torqued to spec in the rod. That doesn't mean it's ok just to put it together. For instance my rods has too much clearance I had to get other bearings for 6 of them.
I'm not sure what you mean by keys. The big chamfer on the big end of the rod must go outward on each journal. Otherwise you have a square side of the rod running on the radius cut into the crank. Also look at your rods they have numbers etched into them at the big end on the rod and cap. They will face up towards the cam when installed right.
Post some pictures of your are confused. I did my very first rod backwards but caught it as I was sliding the rod down to the crank.
Old May 1, 2015 | 11:01 AM
  #44
Fellenz's Avatar
Fellenz
I'll grab some pictures.
By key I mean the slot in which the notch that the bearing sits in
Old May 1, 2015 | 11:23 AM
  #45
PA74F250's Avatar
PA74F250
Those are just the locating tangs for the bearings. They won't help you with rod orientation. I know what your going to be doing!
So if you don't have your rods in right that means your bearings probably aren't in the rods right either. Pay close attention to those to there is a top and bottom. They too have a chamfer that corresponds with the chamfer on the rod.
Look on the bright side youre going to be a pro at doing circlips.
When the bearings are right the square side of the rod should have the bearings lining up pretty much perfect. On my other set of bearings the chamfer was very hard to see and when I did not have them in right the bearing on the one side looked longer than the other side. They just didn't mate together right so it was obvious something wasn't right.
