2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Ford sync lockpick mod
Old Apr 19, 2015 | 07:11 AM
dannyboy11222's Avatar
dannyboy11222
? Does anyone know the pin outs for the ford snyc lockpick,the pinouts I need are for a 2013 Ford Expedition with sync. I need the reverse trigger wire and the monitor trigger wire inputs, the reason for this is, I don't like the front camera auto function on the lockpick so I ordered a front n rear parking switcher for the cameras. It works by reverse trigger to activate when the reverse gear is ingauged then switches over to front camera for 10 seconds then cuts out.
Old Apr 20, 2015 | 08:03 AM
dannyboy11222
Ok well I've spent practically at day yesterday searching the forums for the radio harness to the truck, I have the oem radio with snyc/w aftermarket backup camera with a lockpick, if anyone has the wiring harness info for it. But anyway I have a good start on which wires to start of with, I just can't find any info on how to trigger the radio to activate the screen, as do any project I start I will keep everyone posted on or if it works once I get the switcher.
Old Apr 20, 2015 | 08:06 AM
dannyboy11222
This is what I'd like to try out on the radio
Old Apr 22, 2015 | 03:51 PM
dannyboy11222
Ok so after hours of research i keep coming across info on pin 6 of the 24 pun connector as a 12 reverse trigger, pin 6 is what powers the back up mirrors 12v power, I still haven't figured what pin triggers the radios video feed. I'll keep updating as I find more info
Old May 3, 2015 | 12:12 PM
dannyboy11222
Ok so yesterday I tapped into pin 6 n no luck it wasn't the reverse trigger wire. So I will have to find a green/brown wire on the passenger side kick panel to tap into, that should be the reverse light wire, also no luck on tapping into the monitor trigger, so tomorrow I'm hacking into the lock pick wires myself to see what wires trigger the screen, time to play hard ball ��
Old May 8, 2015 | 07:02 AM
dannyboy11222
Ok well I've tryed splicing ever wire connected to the lockpick but still couldn't figure out how to active the screen, so after hours of research n splicing wires I'm giving up on this project, oh well!
Chenzo
Jan 11, 2015 01:54 PM
A/Ox4
May 25, 2011 01:07 PM
digitalamish
2009 - 2014 F150
Jun 12, 2009 10:53 PM
sail2244
Aerostar
Dec 7, 2005 11:42 AM
maxx-magnum
Feb 19, 2005 11:05 PM
