2 Speed- 12 volt Blower motor
Old 11-20-2017, 06:53 PM
Flat Ernie's Avatar
Flat Ernie
Flat Ernie is offline
I've actually had good luck with small pancake cooling fans off of ATV or something - SPAL makes a 4" and a 5" that move a fair bit of air. They're also thinner, so you can often move the heater box closer to the firewall (depending on your model of heater) and while I never needed a two-speed, I'm sure you could run a 2-speed switch (the kind that has a resistor)...
Old 11-22-2017, 07:53 AM
gogoat's Avatar
gogoat
gogoat is offline
Hey Greg, I did the same years ago. The 6 v motor really blew air. Lasted almost thru the first winter before it burned the windings.
Old 11-22-2017, 07:52 PM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
I use 6v heater fans all the time with a resistor network to lower the current. So far no failures. This is a basic schematic for a GM resistor pack, I just eliminate the direct high speed line by cutting the connection that does not go through the resistors. so with this setup I would end up using the middle two positions and either end would be OFF. I have a whole write up with diagrams and pictures in the truck #2 build thread, check out post #255, link is in my signature.
Old 02-10-2018, 08:14 PM
dadgonebroke's Avatar
dadgonebroke
dadgonebroke is offline
'56 F100 12 volt heater motor-3 wire
Sorry to rehash this but has anyone figured out a parts store replacement heater motor replacement for these trucks. Again, the VDO PM351 fits but it's a 2 wire- one speed and stop -motor. It needs to be a 3 wire- hi speed-low speed- off. I hear some mention of Ford Falcon fitting but maybe we can get some feedback on this?
Old 02-10-2018, 08:45 PM
merten's Avatar
merten
merten is offline
Originally Posted by arctic y block
Cant you just use a two speed switch?
Or reducer?
Did you try a 2 speed switch?
I have this one on order from an ebay vendor because I am replacing the 6v with the recommended VDO motor. My '53 came with the fresh air heater with a 2 speed switch. My switch is bad.
https://www.ebay.com/itm/COLE-HERSEE...53.m2749.l2649
Old 02-11-2018, 10:02 AM
Indybeer's Avatar
Indybeer
Indybeer is offline
I picked up a 2 speed blower motor from my local auto parts store...I believe it was made by Everco...I can check tonight if needed.
Old 02-11-2018, 12:12 PM
dadgonebroke
heater motor
This seems to be a pretty commonly asked question with no concrete answer- so any help is good!
Old 02-11-2018, 03:17 PM
tacson's Avatar
tacson
tacson is offline
Originally Posted by dadgonebroke
I heard a comment today that the blower motor for '71-'77 Ford Mavericks also work. Anyone have experience with this?
This application does work. I have one that was sourced from O'Reillys Auto parts in 09' in my 55. No issues. At the time it was less than $30. I hope this helps
Old 02-11-2018, 03:50 PM
dadgonebroke
Was yours a two wire motor or 3 wire. Rock Auto shows a vdo pm351- which is a two wire (single speed) motor.
Old 02-11-2018, 07:06 PM
tacson's Avatar
tacson
tacson is offline
It is two wire
Old 02-11-2018, 07:28 PM
dadgonebroke
It is two wire
Then it's a single speed isn't it?
Old 02-12-2018, 09:41 AM
Indybeer's Avatar
Indybeer
Indybeer is offline
2 wire will be a single speed. Need 3 wires for 2 speed. I checked what I have installed, but the way it is mounted I can't see the tag to get a part number off it.
  #28
Old 02-12-2018, 11:15 AM
dadgonebroke
We're getting close!
  #29
Old 02-12-2018, 07:57 PM
merten's Avatar
merten
merten is offline
Update. Switch arrived today. The VDO 2 wire motor combined with Cole-Hersee switch gives you a 2 speed heater blower. The switch fits in the original location and accepts the original ****. The ceramic cylinder that encases the resistor coil does get hot on low speed. Probably why later model Fords including Mustangs, with the 2 wire motors, had the resistor coils moved into the blower housing were the fan could move air across them?
  #30
Old 02-13-2018, 08:10 AM
dadgonebroke
Blower motor
I do appreciate the two speed switch option but a lot of guys are wondering about getting a correct type two speed heater motor. Someone has to have some good info on this!
Quick Reply: 2 Speed- 12 volt Blower motor
