Charging problems
Old Apr 18, 2015 | 01:25 AM
Mennenga69's Avatar
Mennenga69
Charging problems
Bought a 93 f350 with a 460 in it recently. Driving at night I noticed it lost charge and the alternator didn't seem to be working. Had it tested and alternator is fine. The motor had been removed prior to me buying the pickup. I found that the block ground wire was not connected to anything on the pickup except for the block. Could this be causing my problem and where do I reattach this ground at? Thanks in advance.
Old Apr 20, 2015 | 08:53 AM
cbakker's Avatar
cbakker
The ground cable is supposed to be attached too the block on a threaded stud below cylinder 1. You may have a corroded or loose connection, so try cleaning them up a bit and making sure they're tight. Also check your belt tension around the alternator pulley.
JR2980
Jul 24, 2014 02:25 PM
jaydgraff
Apr 26, 2013 12:57 PM
feedle
Apr 8, 2011 01:18 PM
michaelgordon@attbi
Jul 3, 2003 03:56 PM
Joe
Oct 18, 1999 05:21 PM
