Torque converter nuts thread??
Old Apr 17, 2015 | 03:13 PM
SuperDad's Avatar
SuperDad
I misplaced the Torque converter nuts for my 1994 Bronco. Does anybody know what thread they are? Someone told me I had to buy them from the dealer? Is that correct?
Old Apr 17, 2015 | 08:40 PM
xlt4wd90's Avatar
xlt4wd90
You probably should use the proper nuts for the specific application. I would go find a similar truck with the same transmission at the local scrap yard and pull them off. You can remove the starter and access the nuts through the hole, and turn the engine with the damper bolt.
I did this for my Aerostar when I rounded off the corners of the TC nuts. I thought the van was supposed to be "all-metric", so I tried using a 14mm or 15mm socket, which stripped the corners of the hex. It turned out to be 9/16". It was surprisingly easy to remove those nuts once I got the correct socket on them. The transmission is an A4LD, so I could find it in Rangers and early Explorers. I'll bet your Bronco uses the same transmission.
Old Apr 18, 2015 | 08:13 AM
stuart1's Avatar
stuart1
Yup. Dealer, transmission shop or salvage yard are the only places.
Old Apr 19, 2015 | 03:43 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
don't forget ebay.these are e40d for example;
http://www.ebay.com/itm/Ford-E40D-E4OD-Transmission-torque-converter-nut-set-/260991785894?hash=item3cc4529ba6&vxp=mtr
herbiemin
May 9, 2015 01:29 PM
desperado_18_2000
Feb 4, 2011 04:29 PM
03scf250
Mar 5, 2009 09:31 PM
z1121jack
Aerostar
Jun 27, 2008 01:01 AM
jamesjinks
Jul 11, 2004 09:14 PM
