Need help with squeaking pully/belt.
Old Apr 17, 2015 | 02:17 AM
dustinsheeler717's Avatar
dustinsheeler717
Okay guys I really need some help and I'm starting to get really frustrated.. 07 f250 I just replaced the power steering pump. I put the serpiten belt back on and when I started my truck I now have a squeaking noise. It's driving me nuts and the more I push the pedal it gets alil louder. Now before I did the ps pump I did hear a little noise like of bearings squeaking when I put my ear to grill.... I put the old ps pump pully on the new pump but I don't think that is it because it is pressed on. Do you guys think it would be a bad idler/tension pully? Is it just a coincidence after I do ps pump that it now decides to squeak????? Please any help/experience would help... I just want to drive my truck and not have problems.
Old Apr 17, 2015 | 07:07 AM
LiftedBlackHD's Avatar
LiftedBlackHD
Couldnt tell you the problem but mine has squeaked for about 5 years. I have a new belt and will be replacing soon.
Old Apr 17, 2015 | 09:43 AM
r2millers's Avatar
r2millers
I'd check to be sure the new PS pump is installed square to belt. If at a slight angle due to a spacer or such, it will howl like a dog.
Old Apr 18, 2015 | 03:44 PM
dustinsheeler717
okay so I've replaced bearings in one of the idler pulleys and just replace another one and still have the squeaking... Does anyone know a good way i can check to the power steering pump pulley to make sure it is squared up??.
Old Apr 18, 2015 | 04:33 PM
Jeff Watts's Avatar
Jeff Watts
You need a new belt. The old one is getting worn. It's probably stretched a bit, and that's what's causing your problem. I put a new tensioner on mine, still had the squeak, put a new belt on it, and squeak was fixed.
Old Apr 18, 2015 | 06:22 PM
WatsonR's Avatar
WatsonR
You may have an A/C clutch going out. Mine did and I thought it was the power steering pump until it started smoking.
Old Apr 18, 2015 | 06:26 PM
Jeff Watts's Avatar
Jeff Watts
I would try the belt first. Worst case, you have a spare belt in the toolbox.
Old Apr 18, 2015 | 06:48 PM
WatsonR's Avatar
WatsonR
Me too! You don't want to do the A/C stuff... $$$$
Old Apr 18, 2015 | 07:08 PM
dustinsheeler717
The belt is fairly new. It still has the writing on it nice and clear. for some reason I think it's the pully for ps pump because it did not start until I replaced ps pump. Could someone please look at there ps pump pulley for me and tell me how far it is seated on the ps pump shaft.
Old Apr 18, 2015 | 07:10 PM
dustinsheeler717
I'm told it should be flush. I'd just like to know from someone else
Old Apr 19, 2015 | 09:35 AM
dannyboy950's Avatar
dannyboy950
It is supposed to be flush. The older remover/installer tool bottoms out before it is flush with the pully. You need to install a washer that fits and finish drawing it on. You will get anything from a squeal to it cutting the last rib off the belt.
4CFarms
Jan 20, 2015 07:45 PM
97-psd
Dec 14, 2010 03:15 PM
93 mix 'n match
1997 - 2003 F150
13
Mar 21, 2010 09:03 PM
Rafter S Tom
Apr 5, 2009 08:36 PM
ASMincBrian
Oct 27, 2006 07:16 AM
