Clutch fan working?
Old Apr 17, 2015 | 01:17 AM
killfrosty's Avatar
killfrosty
Clutch fan working?
how do I know if I need to replace my clutch fan in my 93 Ford f250 7.5 liter?
Old Apr 17, 2015 | 08:33 AM
Conanski's Avatar
Conanski
If your truck sounds like it's trying to suck the grill in through the rad. Engine off and cold the fan should easily turn by hand, it may not spin if you give it a flick but it should turn without much effort.
Old Apr 17, 2015 | 12:12 PM
dixie460's Avatar
dixie460
Well, after sitting for several hours you should hear the fan moving plenty of air at startup til you get the RPM's off idle for a few moments. This is because the clutch fluid has settled out of place and is partially locking the fan up.
Then you'll hear it less and less as it starts to freewheel while you drive and the fluid settles into place. Once the engine is up to temperature and the 'stat opens you should be able to let the truck idle with the a/c on without overheating. When you rev it up again you should hear the fan pulling air again, if it's working right.
Old Apr 17, 2015 | 02:36 PM
killfrosty's Avatar
killfrosty
I really appreciate the help guys
myakkacracka
1983 - 2012 Ranger & B-Series
22
Oct 24, 2017 12:22 AM
74baja
Oct 7, 2009 08:54 PM
FE352
Feb 3, 2008 11:47 AM
stockernavstar
Mar 5, 2006 03:50 AM
brents
13
Apr 25, 2001 08:26 AM
