engine squealing
Old Apr 15, 2015 | 02:15 PM
jmuma2011's Avatar
jmuma2011
engine squealing
hey guys I need some help, I have a 1997 F350 7.5L I just put new heads on and now when I start it, it has a very loud engine squeak. I have checked all pulleys and I have even taken the belts off and started to see if it was any of the accessories and it was still there. So my next guess would be the water pump is bad. any ideas of what it would be before I tare it all apart?
Thanks for the help.
Old Apr 15, 2015 | 06:05 PM
jmuma2011's Avatar
jmuma2011
now that Im thinking about it idk why I thought it would be the water pump since its belt driven. I pulled all the belts off and it still made the noise.
Old Apr 16, 2015 | 06:02 AM
DeepRoots's Avatar
DeepRoots
no belts and still squeeks?
one time squeek or constant?
Does it change with rpm?
could just be a very minor vacuum leak.
Another option is something with the transmission/flexplate that could just be barely rubbing. Of course I dunno what the squeek sounds like, so I might be totally off base.
Old Apr 16, 2015 | 08:27 AM
jmuma2011's Avatar
jmuma2011
its a constant squeak while its running. when I rev it up it goes away for a second but then it comes right back..... I took a video of it but idk if I can upload it up on this site so you guys can hear it
Old Apr 16, 2015 | 08:31 AM
Turbo Dog's Avatar
Turbo Dog
You can put the video on YouTube and then paste the link for it into a reply here.
Old Apr 16, 2015 | 09:46 AM
jmuma2011's Avatar
jmuma2011
good idea....here it is....
Old Apr 16, 2015 | 11:50 AM
jmuma2011's Avatar
jmuma2011
figured it out.... stupid mistake on my part. I was in to much of a hurry putting it back together and forgot to scrap the old gasket off the upper intake so it wasn't sealing right. took it off cleaned it up and no more noise.
Old Apr 20, 2015 | 10:46 AM
DeepRoots's Avatar
DeepRoots
Yeah, most times it is just a very minor intake leak. Annoying because you might still have 22inches of vacuum and yet have that tiny leak.
Old Apr 20, 2015 | 12:57 PM
Turbo Dog's Avatar
Turbo Dog
Even if you still have 22" of vacuum you would need to fix the leak because it would make one or two cylinders too lean.
Old Apr 21, 2015 | 07:07 AM
DeepRoots's Avatar
DeepRoots
Don't remember saying you didn't need to.
Jennmiller1985
General Automotive Discussion
Sep 18, 2018 07:17 PM
Justin Muzarol
Aug 25, 2015 02:33 PM
thbowen
Nov 22, 2013 02:24 PM
79302ranger
Dec 29, 2008 05:34 PM
Wakeboarder141
1978 - 1996 Big Bronco
Mar 28, 2005 07:58 PM
