Sponsored by: Real Truck
Water pump bad?
Old Aug 25, 2015 | 08:18 AM
Justin Muzarol's Avatar
Justin Muzarol
Water pump bad?
I have a 1995 f350 7.3 I'm getting a squeaking noise from under the hood I'm not sure if it's the water pump going the fan won't rock back and fourth how else can I tell if the water pump is bad
Old Aug 25, 2015 | 08:23 AM
KellyfromVA's Avatar
KellyfromVA
Could be the clutch fan or idler pulley is making noise. Usually a water pump failure shows signs starting with gradual coolant loss from the weep hole out the bottom of the pump near the shaft. If the truck sits in place while running for a few minutes, are you getting a little puddle of coolant under the engine compartment?
Old Aug 25, 2015 | 10:27 AM
slpcth's Avatar
slpcth
Water pumps generally leak water when they go bad. Most underhood squeaking noise is caused by bad idler or tension pulley bearing. Loosen the belt and check each one for wobble or roughness. They should spin smooth with no play in them.
Old Aug 25, 2015 | 10:30 AM
Squisher's Avatar
Squisher
If your serpentine is older at all. Gatorback to replace it. I thought my belt was fine and hunted a noise forever until it turned out to be the belt itself.
Old Aug 25, 2015 | 11:28 AM
r2millers's Avatar
r2millers
I agree. Water pumps don't normally squeak, they start to grumble and leak.
Get a long screwdriver or specific listening tool and carefully poke around. It won't take long to isolate.
Old Aug 25, 2015 | 02:33 PM
Thor'sHammer's Avatar
Thor'sHammer
Is it a "chirp, chirp, chirp"? Almost evenly spaced noises? If so, it's your vacuum pump about to fail.
Jennmiller1985
General Automotive Discussion
Sep 18, 2018 07:17 PM
Brower78
Aug 10, 2018 10:28 AM
Restlesswildman
Nov 5, 2013 09:58 PM
Elmo154
Jun 10, 2011 12:08 PM
79302ranger
Dec 29, 2008 05:34 PM
