Off the digital gauges, yes, about 690 to 720 is idle. It's hard to read on the tach. Mine shows about 1200 to 1250 hi idle as I am using the charge protect wire and it does go up right away but slowly can decline.
checked the alternator wire as it is going into the battery and it looks like it is only putting out 38 on hot idle, and 40 on high idle. looks like it is time for a new one.
I've looked at the advance auto site and found this one.
It would probably be expensive as hell since they cater to the government it seems like but there is a company called Penntex that makes kits for our trucks. Mine is an ex-emergency response vehicle and it has a 200 amp alternator in it. one of these days im going to call and see how much a replacement will be.
use coupon code TRT30 at Advanced on-line to save 30% or $50, get the 2005 140amp new, not a rebuild and lifetime warranty. Then select your store, stock check the part and then go pick it up.
well I went to advance auto and had them check the alternator and there machine said "open diode" I believe. I picked up the one in the link I have above and now my voltage seems good. also my truck is a 2006. i'll check the amps with my clamp meter shortly. hopefully this is the end of changing parts for a little bit! Thank you all
About 70 amps and 95 amps at hot idle (not hi idle). I was able to use a clamp meter and measure mine hot idle 95 amps, 110 at high idle. My truck came new with a 140 upgrade and I ran it for 8 years with no trouble. I keep as a spare but am running a PRestolite 230 amp unit in my signature. Its actually for the International version of VT365 and its direct bolt in, you use your existing small pulley. They use these alteranators in international LCFs and F650 and F750s I beleive. My brother ordered it from his international dealer, hes on the parts counter. For me, ordering a DC unit is impossible. I am getting about 175 hot idle, over 200 high idle, but its brand new. We shall see how she does over the longer term....
If anyone is interested I believe this is the alternator he was talking about.
Yup, that's the one, only mine is not black, it does not have the coating on it, just plain. Works good so far. To the original OP, are you reading amps or volts at the charge cable? Do you have a DC clamp meter and know how to read it? I would be interested to see what amps your new one is doing now, just for reference purposes compared to the old ones 40 amps. I am in a cold climate and I need the 230 amp in winter for cold temps short trips, summer she is charging 4 batteries a lot, pulling the RV. 140 I have was still working but in winter I was having to run the charger overnight from time to time.
Good deal! The 2005 fits the truck as you probably already know.... trucks happy, your wallet's happy... if you used the code.
Yea I had them test it and then ordered it on my phone so I could get the $50 discount . While waiting for the order to process I pulled the old one off in the parking lot. 15 min later he brought out the new one and hooked it up. The whole thing didn't take longer than 30 min.
The best high amp alt's are the ones with remote regulators and cooling fins on them,they are also the most money but they are the most dependable units out there. Oh and they are still cheaper than DC for the same amperage over 230 amps
