So I treated my truck the other night and washed it, and I popped the hood and washed the motor off, now when I start it it idles high and while I'm in gear it bogs way down and wants to die (while moving, low rpm) and it's very sluggish when I'm on the Hyway in each gear.. The truck is a 92 F150 4.9 5spd.. I posted this on facebook and was told to pull each spark plug wire to look for a dead cyl I did that and nothing, I thought it was the TPS but not sure, so while I was pulling plug wires I found this lose wire chillin by it's self..
It's definitely worth a shot. I'm still trying to think of what could have just gotten wet and is shorting out. The fact that it happened right after you washed the engine is a big red flag.
However, the computer should show what signal is getting screwy and point you in the right direction.
Ill just use a paper clip to jump the self tester and get he codes that way
