Part needed
Old Apr 15, 2015 | 09:39 AM
harleymsn's Avatar
harleymsn
NumberDummy post from the 61-66 forum last September
1961/64 F100/700 with Warner T-98 4 Speed:
C0TB-8112130-A .. Transmission Cover Weather Pad / 2" I.D. x 7" O.D. x 2" thick / Obsolete
C1TB-8112130-A .. Transmission Cover Weather Pad / 3 3/8" I.D. x 7" O.D x 2" thick / Obsolete
No Ford dealer or obsolete parts vendor has either type.
Old Apr 15, 2015 | 11:39 AM
abe's Avatar
abe
Originally Posted by harleymsn
Strangely, for 53-58 it shows that this is NOT for the F100
Is that because 53-56 F100's came with three on the tree unless a four speed was ordered as an option?
raytasch's Avatar
raytasch
Believe Nothing
"Transmission Cover Seal" I think that explains the confusion, it's not considered a transmission part, but rather a sheet metal or 'body' part so this is listed in the body part section of the parts catalog.
Wouldn't the late F 1s and F100s all have had column shift? I've not looked at the parts book to see when the four speed was no longer available in the light trucks.
Old Apr 15, 2015 | 12:34 PM
Harrier's Avatar
Harrier
Very good info guys. You know, I love the parts catalog and think everyone should have a copy. But, I sure wish you could search it...dang.
So, what material is that made of? I would think it would be pretty easy to make one....well it might be easier to buy one, but what is the fun in that.
I would have thought that the metal ring would go on the bottom to give a solid platform for the seal. Having it on top would give you metal to metal between ring and transmission cover, unless you added another gasket. I wouldn't see the point in the metal ring on top???
Old Apr 15, 2015 | 01:40 PM
bigwin56f100's Avatar
bigwin56f100
Another case where the book is wrong! Yes F100's came with the 4 speed and yes they had a insulator ring on top of the trans. It also has an alignment tap that fits over the center shift rail hump. Look at the pics
Old Apr 15, 2015 | 04:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
"Transmission Cover Seal" I think that explains the confusion, it's not considered a transmission part, but rather 'body' part so this is listed in the body part section of the parts catalog.
Strangely, for 53-56 it shows that this is NOT for the F100
Says nothing of the kind.
1953/56 81 Conventional Cab which means all F100/900 (except C/F - Cab Forward) and body styles 84 & 85 which are Open Drive-Away's.
Old Apr 15, 2015 | 04:04 PM
harleymsn's Avatar
harleymsn
1953/56 81 Conventional Cab which means all F100/950 (except C/F - Cab Forward) and body styles 84 & 85 which are Open Drive-Away's.
Oh, my mistake, thanks for clearing that up. I guess I am too used to C meaning the F1
Old Apr 15, 2015 | 04:10 PM
NumberDummy
I couldn't quote the post you quoted of mine, but here's the related pic.
Basic part number 12130 shown in the pic is a body part. The Body section in the text is required to add on the apropos prefix and suffix (if applicable) to get the complete part number.
Old Apr 15, 2015 | 04:27 PM
NumberDummy
You wouldn't have a 4 speed on the column (4-on-the-tree) unless you had a 1963/64 Econoline, Mercedes-Benz 219/220 or a Citroen ID 19/DS 21.
All the F1/F100's were available w/a 4 speed (F100 cancelled after 1983). 4 speed replaced by 5 speed in F150's beginning in the late 1980's, today you cannot get any M/T in an F150.
Old Apr 15, 2015 | 11:53 PM
fabieber's Avatar
fabieber
Originally Posted by Harrier
Well that's interesting. It looks like that is exactly what we need for the T-98, but the catalog (Others have it too now that I know what to look for) says it is for the 48-52 trucks. So did Ford move to something else for our trucks?
Sounds like a question for NumberDummy.
I think Carpenter is right - at least right to the extent that the shape of the seal is not round as it is on my '55.
Old Apr 16, 2015 | 06:12 AM
Harrier's Avatar
Harrier
Excellent info guys, like always. Now to find a good material to use to make one.
Old Apr 16, 2015 | 09:18 AM
Cougar54's Avatar
Cougar54
The Carpenter piece is the same shape as the part I pulled from my 1950 F2 4 speed which I assumed was original.
Ptjsk
Apr 2, 2019 09:21 AM
MJ's59
Jun 2, 2018 11:11 PM
Russ74
Feb 7, 2017 08:28 AM
MIKES 68 F100
Oct 27, 2012 07:20 PM
frigerator
May 26, 2009 11:40 AM
