Modular V10 (6.8l)
Compression and Leak Down Test
Old Apr 13, 2015 | 10:20 AM
69_Eliminator's Avatar
69_Eliminator
Hello All, I am wanting to do a compression and leak down test on my '99. I am in the process of taking my intake manifold off and putting new gaskets on and figure I better do these tests now in case I need to tear the motor further apart and do the cylinder head gaskets- would stink to put it all back together and it still smoke.
My question is this: for the compression test I will obviously need to turn the engine over. I have my coils out and injectors disconnected in preparation to pull the intake. Do I need to do anything else other than pull the spark plug and crank it?
Old Apr 20, 2015 | 07:39 AM
69_Eliminator
Monday Bump
Old Apr 20, 2015 | 10:41 AM
truckfella's Avatar
truckfella
I believe you need to give each cylinder a little squirt of oil for the rings to seal properly. Otherwise you might get a false negative.
Old Apr 20, 2015 | 11:04 AM
69_Eliminator
That's a good point, might not be a bad idea to do that, especially since it's day for past week. Do i just squirt some down on the piston when it's at TDC and it will run where it needs to and do I need to wait a few minutes for it to flow to where it needs to go? Thanks!
Old Apr 20, 2015 | 11:20 AM
truckfella's Avatar
truckfella
I normally just give each cylinder a couple of squirts right before I install the gauge and just crank it over a few times for the reading, to be sure the oil gets dispersed evenly.
Old Apr 20, 2015 | 11:40 AM
69_Eliminator
Ok, so since I have a bad head gasket as a culprit here do you think that I should squirt some oil down the spark plug hole, crank it a few times, thread the compression tester into spark plug hole, see what the compression is and then put it on TDC compression stroke and do the leakdown test then? I was planning on pulling the valve covers to see when both valves are closed and put it on TDC.
Thanks for your help!
69_Eliminator
Modular V10 (6.8l)
16
Dec 15, 2015 12:28 AM
Bstaff
1997 - 2003 F150
Sep 25, 2015 06:20 PM
truck crazy man
17
Feb 6, 2014 07:50 PM
TheNomad
Jun 18, 2008 08:35 PM
madcapper
26
Jan 29, 2007 11:30 AM
