G-40p
Old Apr 12, 2015 | 07:09 PM
billyf-150's Avatar
billyf-150
G-40p
Can I put g-40p heads onto a 302 roller motor or 351windsor roller motor with no problem or will I ever run into clearance prob,will the stock pistons catch the vaulves orno I need after market pistons with a indentation on the top.
Old Apr 12, 2015 | 07:29 PM
f100beatertruck's Avatar
f100beatertruck
Unless you're running some really high compression pistons, you should have no problems. The exhaust is the one trouble spot.
Use:
Ford Racing Part # M-9430-T50 for the 302
Ford Racing Part #: M-9430-T58 for the 351.
Unfortunately I just checked and they're no longer available. So you'd have to search for something similar or get some GT-40 heads instead.
Old Apr 12, 2015 | 08:32 PM
TexasGuy001's Avatar
TexasGuy001
Due to the exhaust issue, I'd never consider using these heads.
gman97005
15
Jan 23, 2016 11:55 AM
Cobra-Kai
13
Apr 1, 2014 04:28 PM
jonbass40
Feb 26, 2010 09:00 PM
RC Dan
Apr 9, 2007 06:18 AM
ratthell52
May 18, 2003 10:38 AM
