EFI injector problems
Old Apr 12, 2015 | 01:02 PM
miashley150's Avatar
miashley150
Working on a 92 EFI F150
I believe it is an early 92 model because when the parts guy looked up the intake gasket kit for a 92 the egr gasket was incorrect but was correct for a 91 ( correct me if i am wrong)
Engine barely ran, with huge miss
Rats chewed cylinder number 3 and 7 injector wires
After rewiring injectors with new wire clips the motor still did not run except at full and half throttle
Pulled plugs #'s 1,4,5,8 were dry and slightly carboned up (normal burn) #'s 2,3,6,7 were clear clean fuely and (not burning)
Ran a compression test on all cylinders and got 135psi on all 8
Replaced distributor upper and lower cap and each cylinder is receiving ignition (broke it in the plenum removal process)
after removing all spark plugs I noticed large amounts of fuel coming out of the middle four cylinders ( # 2,3,6,7)when spinning it over with ignition on. ( large drops hitting the fender wells). So I unplugged the injectors and spun the motor over again with ignition on, and there was no fuel coming out.
So i concluded that the injectors weren't hung but the computer was telling those plugs to open for too long (ie full throttle.)
Tried disconnecting the battery and resetting the system, however the same result occurred
What do i do now?
Any help will be greatly appreciated. Ive already been paid too much for my time on this job and need to fix as soon as possible.
Old Apr 20, 2015 | 11:34 AM
Conanski's Avatar
Conanski
I'd say you still have some chewed wires to find.
miashley150
Apr 12, 2015 07:53 PM
slinger34
General Automotive Discussion
Mar 22, 2009 09:05 PM
lawnboy58
Bronco II
Oct 3, 2008 11:59 PM
genjock
1983 - 2012 Ranger & B-Series
Jun 11, 2006 03:30 PM
greystreak92
Mar 29, 2003 03:27 AM
