EFI injector problems
Old Apr 12, 2015 | 12:56 PM
miashley150's Avatar
miashley150
Working on a 92 EFI F150
I believe it is an early 92 model because when the parts guy looked up the intake gasket kit for a 92 the egr gasket was incorrect but was correct for a 91 ( correct me if i am wrong)
Engine barely ran, with huge miss
Rats chewed cylinder number 3 and 7 injector wires
After rewiring injectors with new wire clips the motor still did not run except at full and half throttle
Pulled plugs #'s 1,4,5,8 were dry and slightly carboned up (normal burn) #'s 2,3,6,7 were clear clean fuely and (not burning)
Ran a compression test on all cylinders and got 135psi on all 8
Replaced distributor upper and lower cap and each cylinder is receiving ignition (broke it in the plenum removal process)
after removing all spark plugs I noticed large amounts of fuel coming out of the middle four cylinders ( # 2,3,6,7)when spinning it over with ignition on. ( large drops hitting the fender wells). So I unplugged the injectors and spun the motor over again with ignition on, and there was no fuel coming out.
So i concluded that the injectors weren't hung but the computer was telling those plugs to open for too long (ie full throttle.)
Tried disconnecting the battery and resetting the system, however the same result occurred
What do i do now?
Any help will be greatly appreciated. Ive already been paid too much for my time on this job and need to fix as soon as possible.
Old Apr 12, 2015 | 02:23 PM
subford's Avatar
subford
Sounds like the white wire circuit #556 is shorted to ground or is grounded in the computer.
Old Apr 12, 2015 | 02:41 PM
miashley150
How can I find this white wire circuit? Is this the white wires that are wired into the injector plugs? Are the middle 4 cylinders wired together? Obviously if it is in the computer then the computer needs to be replaced but first I need to check for faulty grounding (a short). But where?
I will check online to figure out what white wire circuit #556 is. I don't have any books or manuals.
Any help is greatly appreciated
Old Apr 12, 2015 | 03:23 PM
subford's Avatar
subford
Yes it is.
Yes they are.
I would think it would be a wire shorted to ground or to a ground wire.
Could be a shorted transistor but not likely but it has happened.
A 1995 diagrams but should be close to what you have:
Old Apr 12, 2015 | 03:53 PM
miashley150
Extremely helpful. I will look into this Monday when I am around the truck.
Too bad I will probably have to pull the plenum again to see the bundle of wires.
Still curious as to what caused this mess in the first place. The rat, who I found too be living in the hood, chewed up 2 injector wires and and 3 vacuum lines.. why isn't it as simple as reconnect the wires and lines and go...
Guess I missed a short in the wiring the rat got to.. although I've been up and down the wiring. I don't see how the computer or a transistor could go bad all the sudden.
But this is how it always goes.
If it was easy everyone would be a mechanic
Old Apr 12, 2015 | 06:42 PM
RIKIL's Avatar
RIKIL
Have you pulled the codes?
Old Apr 12, 2015 | 07:53 PM
miashley150
No i have not. I will have to read up on how to do that again
alex22
Jan 8, 2016 11:59 PM
miashley150
Apr 20, 2015 11:34 AM
calebo10
15
Mar 29, 2015 04:10 PM
Sea2jet
Aug 4, 2011 09:52 PM
weswes01
Jan 9, 2006 10:48 PM
