Need help ASAP
Old Apr 13, 2015 | 12:17 PM
willydmax's Avatar
willydmax
A friend of mine had something similar happen only he caught it before they finished filling the tank. They figured out if you take the rear filter off and cycle the key the lift pump empties the tank out in a hurry. Sounded like a reasonable idea.
Old Apr 13, 2015 | 12:43 PM
donovan's Avatar
donovan
Fuel
Check and change you fuel filter often right now. If you see metal in the filter, you have a issues. Double up on your fuel treatment, for a couple of tanks.
If you have a issues some insurance company will cover the repair.
Good Luck
Old Apr 13, 2015 | 12:56 PM
Dakster's Avatar
Dakster
Just be careful not to smoke when you do that... Hopefully you are doing that into containers. Even though no one can use the fuel for anything other than a bonfire outside.
Old Apr 13, 2015 | 06:08 PM
emd160's Avatar
emd160
Originally Posted by Big-Foot
If I were you, I'd go buy a lottery ticket right friggen now!!!!!! Then get a whole butt-load of Ford Diesel Fuel treatment and cross your fingers....
I'd also buy the extended warranty as that HPFP is not something you want to have to pay for yourself...
Haha yea I would buy a lottery ticket but I'm pretty sure I used all my luck up already. Really hopefull that we caught it in time, we got around 12-16oz of diesel out of the water/fuel separator before it was straight gas and we purged all the lines till it was straight diesel before we attempted to start it. we still had 520 miles to go till home and she ran great the whole way but I'm keeping an eye on things
Originally Posted by senix
Change your fuel filters and I would be opening up the top mount filter to have a look.
It is sealed but I would see about getting it opened up.
If it is full of metal then have it towed in.
Changed the all the fuel filter, oil and filter when I got up this morning. I had to work afternoon so I didn't get to cut it open but I'm going to.
Old Apr 13, 2015 | 06:15 PM
emd160's Avatar
emd160
This is what handles I was talking about, the D is like a handle and it's connected to that little plug looking thing. What are these for? There's two of them on the bottom of the tank
Old Apr 13, 2015 | 06:47 PM
Big-Foot's Avatar
Big-Foot
Pretty sure they are plugs in the plastic shield that protects the fuel tank. You pull those out and it will drain any water/crud that is built up in there before you drop the tank. I will take a look at mine a little later to confirm..
Old Apr 13, 2015 | 06:48 PM
cabindoc's Avatar
cabindoc
I always thought they were used during assembly.
Old Apr 13, 2015 | 07:27 PM
kper05's Avatar
kper05
At half a mile gasoline made it to the hpfp. I agree with senix, bust open the engine and dfcm filters now that it has been driven, look inside the pleats and see if you find metal. If you do, best not to drive it.
I use a punch to carefully split open the seem on that sealed filter.
Also, make sure your tank is 100% back in place and sealed. Water seeping in there wouldn't be good either.
Old Apr 14, 2015 | 06:40 PM
Dakster's Avatar
Dakster
I thought those handles were for assembly as well. I didn't think it was a "plug" that could be removed and replaced. Something to use to hang up the fuel tanks on a line for a tech to grab and then use to help put the tank on the truck. I could be wrong as well...
Also, +1 to Senix and Kper05.
Old Apr 14, 2015 | 08:47 PM
emd160's Avatar
emd160
I broke open the filter this morning, opened the pleats up and didn't see any metal of any kind. Even went as far as taking the magnifying glass to look. I'm going to run it awhile and change them out again. When we pulled the sending unit out it was all smooth on the inside and that's what had me curious as to what they where for. I though maybe to handle the tank during assembly but wasn't sure
Old Apr 14, 2015 | 11:19 PM
Dakster's Avatar
Dakster
Sounds good emd160. I think you are going to be just fine.
Old Apr 15, 2015 | 05:01 AM
senix's Avatar
senix
sounds like you made out ok in this case.
Old Apr 15, 2015 | 09:26 AM
  #28
my_crib_too's Avatar
my_crib_too
With my truck, two things that I always check and double check.
  1. I am the only person that fills my tank. When filling, I check and double check that diesel is the only thing going in the tank. I don't pull the little handle until I am certain that the correct fuel is going into the tank. For me, I worry when filling up my wife's car. I'm more likely to put Diesel into her car than Gas into my truck. I never use the shared pumps. All pumps where I fuel up are diesel only.
  2. When filling my DEF tank, I never do this if I am in a hurry. Take my time and insure DEF is not going into the fuel tank.
Glad this worked out well for you.
Old Apr 15, 2015 | 06:40 PM
  #29
kper05's Avatar
kper05
Good news on your find. I would bust open the filters next time you change to inspect those as well.
hrb15modracer
Apr 5, 2014 08:28 AM
94 Turbo
17
Feb 7, 2009 10:56 AM
pracing6
General Diesel Discussion
Jul 6, 2008 06:30 PM
Vegas-V10
Mar 14, 2005 02:35 PM
SMB
16
Jan 13, 2005 10:49 PM
